little rubbage issue
Old Jul 26, 2014 | 01:40 PM
Jeeptang's Avatar
Default little rubbage issue
Got a deal on some 37" trails so I went for it. Lift is a 3.5"x- factor. 18x9 xd monster -12 offset.
I rub at full lock on the frame. Are my options to get wheel spacers or just those tabs to limit my turning radius.
Or could I add a lift spacer up front .
Any advice appreciate d
I'd be up for trading for some new 35s and cash maybe. These have 3000 miles
Near Kansas city
Old Jul 26, 2014 | 02:00 PM
Mr.T's Avatar
Community Favorite
Near Kansas city
Adding a washer to the steering stops is practically free, hardly changes the turn radius, and potentially saves stress on the front u-joints. My setup is mild compared to yours, but that's what I did.
Old Jul 26, 2014 | 02:42 PM
Jeeptang's Avatar
Yes steering stops. That word slipped my mind
Old Jul 26, 2014 | 02:50 PM
Mr.T's Avatar
Community Favorite
Yep, knew you meant that. If you do it, look for some relatively small outside diameter washers with a close fit on the inside diameter. There's some casting that can interfere with a washer that's too large. I put some blue locktite on the threads as well, but that's probably overkill.
Old Jul 26, 2014 | 04:44 PM
Jeeptang's Avatar
Post up some pics if you get a chance please
Old Jul 26, 2014 | 05:06 PM
hoghd06's Avatar
Google "steering stops jk". You will find good info
Old Jul 27, 2014 | 10:09 AM
Mr.T's Avatar
Community Favorite
The mechanical pencil in the pic is pointing to the washer installed under the steering stop. Unscrew the stop, re-install with added washer, test for tire clearance, done.
Old Jul 30, 2014 | 05:11 PM
Jeeptang's Avatar
Worked like a charm. Thanks a lot. I splurged and got grade 8 washers. Lol cheapest fix I've ever done
