Lockers
Old Jun 10, 2010 | 04:16 PM
burton57's Avatar
Default Lockers
I had the track lock limited slip in the rear and replaced it with a eaton elocker. I also did 4.88 gears. I love the gears and the elocker has worked perfect so far. I will run another eaton up front in my Dana 30 when I get some more cash. Elocker is cool cause no air lines that leak and it was a clean easy install. I was not a big fan of my limited slip cause it would kill power and try to adjust and make wierd noises when I was trying to crawl up a slick or steep loose trail. I either wanna be locked or open and the elocker gives me that choice. Plus can run regular gear oil with no additives.
Old Jun 10, 2010 | 04:36 PM
Suffolk JK's Avatar
Michele? Are you the one who introduced yourself and Doyle this past weekend at Mettowee? I'm the red JK with Long Island Off Road.
Old Jun 11, 2010 | 05:24 AM
michele07jk's Avatar
yep one and the same! how was your trip home???
Old Jun 11, 2010 | 08:16 PM
Suffolk JK's Avatar
Good. LOTS of downpours. Did the clean JK pretty damn good though!
With those rolling hills, I'd get a selectable up front. I can only imagine how those hills and sides are with lots of snow and ice. Get yourself an ARB up front and a Detroit in the rear. Call it a day.
Old Jun 11, 2010 | 09:02 PM
jeep_n_co's Avatar
Originally Posted by Suffolk JK
Detroits front and rear and call it a day.
The D30 has been around for MANY years and hold up to being locked and wheelin' quite well.
I thought I would relay my recent experience being locked front and rear with non-selectable lockers on my TJ.
Off-road, it was absolutely the way to go. Nothing to think about, everything just worked all the time. Sure, there was some noise, but really no biggie. If my jeep was a dedicated off-road rig, I would go this route again.
On-road in the dry or wet, I liked it. Sure, turning in the parking lot was full of drama and tire squeal, but hey if I wanted to be obscure and invisible, I wouldn't have bought a jeep to begin with.
However, and here's the REAL kicker, it was downright dangerous in the snow and ice on the highway. I live in CO, and in the winter on the highway if you hit a patch of ice, the rear would step out precariously and dramatically. If I had it in 4WD, not only would the rear step out, but the front would step out in the opposite direction, and you would be spinning in a heart-beat.
I got into the habit of clutching-in at the slightest hint of anything that even looked like ice on the highway. Black ice was a death-knell.
As a result of this experience, I would personally never do a non-selectable locker on a vehicle I drive on the street again. If you live anywhere that has four seasons, heed my warning.
I plan on going ARB (with a re-gear) as soon as I can.
Old Jun 12, 2010 | 03:24 AM
ronjenx's Avatar
Thanks for bringing up this point!
I have posted this type of info in the past.
It is summarily ignored by, and/or denied by, those who want full-time lockers.
That is precisely the reason the TRU–LOK™ is limited to engaging in 4lo and below 10 mph.
