Lockers / gearing question
Old Dec 4, 2019 | 06:42 AM
Dat's Avatar
Dat
Default Lockers / gearing question
Not any time soon, but thinking about diff lock, the ones I've seen say they are for 3:73 and up, I have factory 3:21 and stock size tires, not really looking at going much bigger or regearing, my question is, what does the gear ratio have to do with the locker? Why not the locker with 3:21, I don't do any rock crawling, just roads through the deer lease, Wich just get slick more than obstacles
Old Dec 4, 2019 | 06:55 AM
TheDirtman's Avatar
I would suspect there is no demand for a 3.21 locker as bigger tires are a better upgrade as well as gearing before adding lockers.
Old Dec 4, 2019 | 07:03 AM
Dat's Avatar
Dat
Just thinking about better traction, not needing more ground clearance or lower gearing
Old Dec 4, 2019 | 07:04 AM
resharp001's Avatar
Loved
Community Favorite
It's about the carrier size which changes with 3.73 and down (higher numerical value).
I think this permalink should work, and it has a decent explanation from DT. It's really about the height of the ring gear teeth which then causes the carrier to have to change a bit to keep the pinion meshing perfectly -
https://www.jk-forum.com/forums/modi...0/#post1788387
I have never quite thought about it, but I can see how your situation is very unique. Almost nobody is looking to lock a diff with 3.21 gears. It wouldn't make any sense at all for 99.99% of peoples' builds. You are the unicorn. . Honestly, you would be a prime candidate to fine some take off rubi axles with 3.73 gearing and toss em under there, picking up e-lockers in the process. Most people looking for rubi axles aren't wanting 3.73 gearing cuz they'd have to pay additional to regear them. Also, there are way more rubi axles with 3.73 gearing floating around than 4.10 gearing.
Old Dec 4, 2019 | 07:29 AM
Dat's Avatar
Dat
Thanks, I didn't know they used a different carrier with 3:21, I just figured that a Dana 30 was a Dana 30.
makes more since now
Old Dec 4, 2019 | 10:09 AM
Dat's Avatar
Dat
The roads on our deer lease are clay, they don't really have any ruts or anything deep to go through, it's just slick when it's been raining, some of the inclines aren't very steep, but being slick can be hard to get up
Old Dec 4, 2019 | 10:17 AM
nthinuf's Avatar
Which traction device(s) are you looking at?
Old Dec 4, 2019 | 10:22 AM
resharp001's Avatar
Loved
Community Favorite
No doubt. A little rain can often make a simple dirt road harder than climbing some rock obstacle!
Old Dec 4, 2019 | 10:34 AM
Dat's Avatar
Dat
Ha, yeah, that's why I was saying it's just clay, no obstacals other than just slick, I don't need the gearing or bigger tires, stock size works as long as you have good tread. For me, around here, off road is smooth, just slicj
Old Dec 4, 2019 | 10:36 AM
TheDirtman's Avatar
Just look for some used 3.73 take off gears and put in the new lockers. Takes the same amount of install time and 3.73's should be laying around everywhere and be cheap or free.
