Lockers or lift?
Old Feb 21, 2012 | 07:06 AM
benmillr's Avatar
Default Lockers or lift?
I have a stock sahara and looking to do some mods. What should I do first locker or suspension lift? Im new to this and not sure where to start.
Delux2769's Avatar
How do you play? Are you just DD right now?
Old Feb 21, 2012 | 07:10 AM
rays0852's Avatar
If you have a 2 door....LOCKERS
If you have a 4 door.....LIFT
Erock1974's Avatar
Personally after off roading for many years I think lockers are more important then a lift
Old Feb 21, 2012 | 07:18 AM
benmillr's Avatar
This is my daily driver but each weekend I'm out searching for places to offroad. I'm on Florida so it's pretty flat. Got stuck yesterday and did not like it.
Old Feb 21, 2012 | 07:24 AM
benmillr's Avatar
Erock what lockers do you suggest. Can I add front and back at separate times
Old Feb 21, 2012 | 07:25 AM
pbloom95's Avatar
i would go lift and tires first, but if you cant do both then just get a rear locker. It really matters on what you plan on doing. If you want to eventually go to a bigger tire like a 35 or 37 then i would lift it and get the tires, then do you lockers and regear so you dont have to open up the axle twice
Old Feb 21, 2012 | 07:33 AM
benmillr's Avatar
Pbloom what lift would you suggest. Don't want 35.. Those tires are crazy expensive
Old Feb 21, 2012 | 07:45 AM
pbloom95's Avatar
It all depends on how much your willing to spend and if you can do the install yourself.
Old Feb 21, 2012 | 07:50 AM
benmillr's Avatar
1500 max I cant weld
