Locking Dana 30?????
Old Jul 29, 2011 | 08:51 AM
scotty6336's Avatar
Originally Posted by medic_23387
Any problems with your d30 being locked?
Yeah I'd like to know as well. Re-gearing soon and need to replace front carrier, so might as well lock it...Wish I knew someone local with an aussie front to test drive.
Old Jul 29, 2011 | 09:16 AM
nthinuf's Avatar
Do some reading on the TrueTrac also. It is full case, and is very strong. About the same price as buying a lunchbox + a new carrier. It is a limited, so should be less strain on the front drivetrain than a full locker. Uses gears instead of clutches, so will not wear out. With the jk's electronics or a little brake pressure, it will 'lock up' to give closer to locker level performance when needed. And it is much more user friendly if you happen to drive on winter roads. (can you tell that this is my favorite d30 traction option? )
Old Jul 29, 2011 | 09:31 AM
scotty6336's Avatar
Yeah thanks I'll do that. It does snow from time to time here in NC, so something a bit more driveable in the winter...I'll do some research.
Old Jul 29, 2011 | 09:40 AM
CA-JK's Avatar
I've been running an Aussie in my front D30 for over 2 years now and I love it. I will eventually be adding a Detroit in the rear but for now I've been running through the double black diamond trails in SoCal with no issues.
I will say that I did break an axle shaft while out on the rocks, but I think it was my fault and not a result of the locker. I was winching myself through a tough obstacle and broke the U-joint. Since then I have gone through that (and many other) obstacles with no issues.
Here's a few short videos of the carnage.
http://s1022.photobucket.com/albums/...t=MOV03703.mp4
http://s1022.photobucket.com/albums/...3DMOV03702.mp4
http://s1022.photobucket.com/albums/...3DMOV03701.mp4
Old Jul 29, 2011 | 09:44 AM
Mark Doiron's Avatar
Originally Posted by CA-JK
... I will say that I did break an axle shaft while out on the rocks, but I think it was my fault and not a result of the locker. I was winching myself through a tough obstacle and broke the U-joint. ...
Stock axle and U-joint?
Old Jul 29, 2011 | 09:49 AM
CA-JK's Avatar
Yep, it’s the weak link in the D30. You can put a cromoloy shaft in the driver's side and equal out the axle strength between both sides but i really don't mind having that go instead of my R&P. It's an easy fix and not nearly as expensive.
Old Jul 29, 2011 | 09:58 AM
familytime's Avatar
JK Forum Regional Rep
Been running ARB up front more than 4 years now,no problems.D30 has C gussets and Alloy Axles,take it slow and you'll be fine.If everyone is so worried about locking the D30,then spend the money on a Pro Rock 44 or 60
Old Jul 29, 2011 | 09:59 AM
I already have Chromolly on both sides. The stock U-joints are a known weak point on the JKs--primarily because of the lack of full C-clips. A cheap upgrade might be just to replace both of the stock U-joints with better, aftermarket products.
Old Jul 29, 2011 | 10:03 AM
nthinuf's Avatar
I can't see the videos, but you broke a ujoint 'while' you were winching? Fix the vids!! I want to see that!!
Old Jul 29, 2011 | 10:15 AM
mkjeep's Avatar
No issues with mine besides changing u-joints. Dana 30, lockright, stock axles. 3yrs
