Locking Dana 30?????
Old Jul 29, 2011 | 10:21 AM
  #21
Dynatrac's Avatar
Sponsoring Manufacturer
Sorry guys but it isn't the stock u-joints that are the problem, it's the stock axle shafts. The ears are weak and they flex. When that happens the clips pop and the u-joint binds and breaks.
Old Jul 29, 2011 | 10:28 AM
  #22
Mark Doiron's Avatar
Thanks for the correction.
Old Jul 29, 2011 | 10:37 AM
  #23
CA-JK's Avatar
Originally Posted by nthinuf
I can't see the videos, but you broke a ujoint 'while' you were winching? Fix the vids!! I want to see that!!
Just fixed the videos. Enjoy!
Old Jul 29, 2011 | 11:02 AM
  #24
ducnek's Avatar
Originally Posted by medic_23387
Any problems with your d30 being locked?
None at all, I do wheel it pretty hard but here in the south its mostly dirt/sand and even where there are rock obstacles they usually allow for some tire slippage.
I also ease thru most difficult obstacles in 4 lo instaed of hammering thru stuff.
Old Jul 29, 2011 | 11:57 AM
  #25
renpia's Avatar
I already have Chromolly on both sides. The stock U-joints are a known weak point on the JKs--primarily because of the lack of full C-clips. A cheap upgrade might be just to replace both of the stock U-joints with better, aftermarket products.
Stock u-joints are Spicers so should be good.
Old Jul 29, 2011 | 02:08 PM
  #26
When the JKs first came out there were reports of people spinning off the caps on their U-joints. The preventative was to tack weld the caps. This flies in the face of what you and Dynatrack are saying, but we were still learning things back in '07. Not trying to say you or Dynatrack are wrong--but there is history behind what I wrote.
Old Jul 29, 2011 | 02:17 PM
  #27
Dynatrac's Avatar
Nope, we're saying the same thing. The caps were spinning because the ears were weak. It wasn't a u-joint issue but the weak ears are still an issue today.
Old Jul 29, 2011 | 03:03 PM
  #28
medic_23387's Avatar
So if I don't have the money to put aftermarket shafts in right now and break a shaft on the trail can I get home or am I stuck
Old Jul 29, 2011 | 03:15 PM
  #29
Dynatrac's Avatar
You'll want to pull the shaft before you drive it home. The JK style unit bearings are ok without an outer shaft.
Old Jul 29, 2011 | 06:26 PM
  #30
can someone explain the inner and outer axle shafts to me. I have never done much with axle shafts. Like what is the meaning of inner and outer is that just the side its on or what. Are there two shafts in each side im lost.
