LOD front bumper
WOL, any tricks or instruction available for installing the rear bumper? I expect delivery in the next day or so. Not sure if I will be getting the "newer" updated version or the older one...hopefully the newer ones with the kinks worked out. The order went in 3 weeks ago.
Side note: I'll be posting a new thread showing the installation of some roof rails on the hard top. My friend at Fisher's Automotive had a set of factory roof racks in his warehouse off a Tahoe. He thought they might look pretty good on the JK. Guess what? They look great! They excet Yakima or Thule load bars with the repsective rail mounts.
I was on the first list to get mine and it took 2 weks from order to doorstep. I bought the front and the rear. I have installed neither since the Jeep is not here. Its been on order since Oct 19, 2006. They both arrived with the boxes beat to hell. The bumpers were ok but there are some imperfections in the powdercoating. I sure hope that I dont have the issues with the rear that some are having.
My JK will be in the shop tomorrow for installation of the front and rear bumpers, so this weekend I'll get some pictures uploaded showing both the racks and bumpers...two different threads though.
If you would, I would like to know what they charged for the install, and how long it took them, any problems, exetra...... Thanx.
Unfortunately, I haven't seen or done an install of the new bumper (which you should be getting) and so I can't say for certain what all you will need to do. If it's anything like the one I got, it should go on easier than the front and at least one hole will need to be drilled through the rear cross member. I'm pretty sure that the new side brackets will require 2 holes (one on each side) to be drilled on the side of your frame rails as well and the brackets should act as your template making it easy to locate where you need to drill.
A few more things for the rear bumper. If you did not get the bumper w/tire carrier you will need to buy (unless they just forgot to give me mine) (8) 7/16" nut's (course thread) and washers for the tire relocation brackets, and will have to drill open (2) holes on the OEM tire bracket.
It took me three weeks to get the bumper.............and three weeks to figure out how to get the last bolt (pass side closest to the sway disco solenoid) into the powerplant winch. If you put this bumper on a Rubi, be aware that bolt on the Powerplant design winch is a bi-atch!
Another problem when using with the Warn Powerplant is the drum does not line up with the fairlead....I will post pics showing this later.
BB
BB
