Long Arm Upgrade Suggestions?
Old May 27, 2014 | 06:16 PM
JKZinger's Avatar
Originally Posted by WARLOCK
Yes I agree, there is a lot of junk on the market.
And I don't believe you can find a real bolt-on long arms kit that is properly designed.
A good kit will require welding and cutting.
Not true at all! I am running the EVO Double D bolt on long arm with my coilovers and it works great. I also wheel it hard. You need to get johnny joints so you will not blow out bushings with the flex the coilovers will give you.
Old May 27, 2014 | 08:38 PM
Maertz's Avatar
coilovers dont give you more flex than any other shock in the same size/travel....
Old May 28, 2014 | 03:23 AM
WARLOCK's Avatar
I would not qualify something that require a lot of cutting and drilling a true bolt-on kit...
EVO double D seems to be a nice kit however
https://www.jk-forum.com/forums/jk-s...nstall-176089/
Old May 28, 2014 | 01:51 PM
JKZinger's Avatar
I would not qualify something that require a lot of cutting and drilling a true bolt-on kit... EVO double D seems to be a nice kit however https://www.jk-forum.com/forums/jk-s...nstall-176089/
How are you going to do it without cutting and drilling to install bolts? Glue!
Old May 28, 2014 | 01:55 PM
JKZinger's Avatar
Go ahead and run bushings with coilovers and see how long they last. You will kill them with the flex.
Old May 28, 2014 | 05:54 PM
Maertz's Avatar
your missing the point. you could run stock bushings for quite awhile on on a 6-8" travel coilover....
Old May 28, 2014 | 06:06 PM
rsbmg's Avatar
I'm going to keep my eye on this thread I feel it could produce some viable candidates for the Absurd things you read on jeep forums thread
To the OP I'm curious why you run a 4'' lift and what you hope to gain from long arms also do you have a budget in mind for the kit?
Old May 28, 2014 | 06:08 PM
Maertz's Avatar
I think damn near every time I browse this forum I get dumber...
Old May 28, 2014 | 06:19 PM
rsbmg's Avatar
That has to be true because if you were smarter your jeep wouldn't still be in pieces in your garage
Old May 28, 2014 | 06:34 PM
Maertz's Avatar
lol good point...
