Long arm VS short arm
Old Jan 14, 2013 | 07:11 PM
  #51
Omani2010's Avatar
Originally Posted by GJeep
BTW, the OP has disappeared...
Ay it's got nothing to do with the person or place where your from I just asked a question and got the reply I needed ... I don't really care if the answer from Israel or India
Didn't come back to it to see if anyone commented or not
BY THE WAY GUYS THANKS FOR THE INFO IM FINALLY STARTING TO UNDERSTAND THESE NOW, we can't modify the ride height more than this here I know people who lifted 4" but I'm not thinking of that ... The ride is comfortable
Old Jan 15, 2013 | 01:27 AM
  #52
GJeep's Avatar
Originally Posted by Rock Krawler Suspension
There are alot of things to concider given this situation! The first things are what are your needs and what is within your budget!
A good long arm setup will always ride better and perform better than a short arm system!
Long arm systems will have reduced axle steering effect as compared to a short arm system over a given range of travel (This one is huge)...
Most major manufacturer's long arm systems are different as well which yields different charecteristics! For us, we put in really high clearance into all of our arm mounting points! We favor the independent 3 link design in JK's for bind free suspension movement! We also make sure to run full length upper control arms, not combinations of long lowers and short uppers which helps minimize axle steering effects of the shorter arms, thus maximizing performance.
At the end of the day, there are alot of pluses and minuses! You really need to figure out what is best for you and the only person that can answer that is you! Or your wife if she holds the check book! LOL.
Good luck with your builds guys. If anyone would like, feel free to give us a shout! We will be more than happy to talk Jeep with you all!
RK
Hey... no need to "defend" long arms Their suspension geometry improvement is obvious.
As far as I'm concerned, you're wrong about one thing, though... My wife doesn't interfere with what I do with my Jeep...
I'm not an avid rock crawler, however, there's no lack here of demanding wheeling, which makes use of every inch of articulation and ground clearance.
One of the good points of the JK/U is the live axles, but this is also a drawback, which properly designed long arms can correct to a large degree.
Now, here's some blasphemy:
My personal approach is that if I wanted to mod all the way, to the most offroad capable possible, it would no longer resemble a Jeep... it would have long arms... on a sort of 4x4 large buggy, all tube-framed, with long-armed independent suspension.
I don't have the time for such a build, or the time to drive it enough to justify such a project.
On the other hand, I'm in love with Jeeps and enjoy mine, be it on trails or in the city.
Also, from my personal point of view (and others may, of course, have a different approach) --
A 4" lift is enough for me, I wouldn't go for 6" or more.
If I had long arms, they would have been hit quite a few times, rather than the side rock sliders. Short arms are less vulnerable, and that's why I have them.
If I had 8" lift, I'd have definitely preferred long arms. In fact, they would have been a must.
With 4" lift as the starting point, and seeing how nicely my JKU "behaves itself", which suspension mod would have bigger influence on ride, both off & on road? -- Long arms, or coilovers?
As this is my DD, which "hits the trails" between 2 and 4 times a month, I think that, while changing to coilovers will be felt on every single bump on the road or off it, I'll feel the true and full effect of the long arms only once in a while.
Old Jan 15, 2013 | 07:16 AM
  #53
Rock Krawler Suspension's Avatar
Former Vendor
Sir, you have a great wife!
The only thing we would like to point out with our systems is the fact that our long arms do have a high clearance feature that provides you with improved cross over angles, even when compared to high clearance lower control arms that mount to the OEM mounts.
Can you spot the long arms below? If we did not put the decals on them, you would be hard pressed to find them! Or so we hope! But, from this side view you can easily see the cross over angle advantage we offer! When it came to our JK Long Arm Systems, we wanted absolutely no compromises for suspension geometry!
RK
Old Jan 15, 2013 | 07:22 AM
  #54
v8zracer260z's Avatar
Veteran: Marine Corp
Can you spot the long arm below?
<a href="http://s708.photobucket.com/albums/ww85/Rock_Krawler_Suspension/?action=view&current=DSC03701.jpg" target="_blank"><img src="http://i708.photobucket.com/albums/ww85/Rock_Krawler_Suspension/DSC03701.jpg" border="0" alt="Photobucket"></a>
RK
Which kit do you have on there and I'm assuming those are 37's too
Old Jan 15, 2013 | 11:43 AM
  #55
GJeep's Avatar
I showed this to my wife.
She said -- "Thank him for me. And, tell him he can get my seat next to you every time you start offroading at crazy angles, in places that are meant for goats and not for cars..."
(Sorry about the 'cars'. She said it, not I... )
RK
Well, those long arms are really tucked in ! Nice design !
Old Jan 16, 2013 | 01:10 AM
  #56
GJeep's Avatar
Good !
You got terrific offroad possibilities - sand dunes, mountain trails, sea shore...
Pls post some pictures if possible
Old Jan 16, 2013 | 09:10 AM
  #57
Former Vendor
That 2 door had a 3.5" long arm, 37's and flat fenders!
RK
