Long arm vs short arm lift
Old Sep 9, 2015 | 11:18 AM
Ripa777's Avatar
Default Long arm vs short arm lift
2014 JKUR. Planning to do small lift 2.5 ". Is there any benefit to going with a long arm system with only 2.5" lift??? It's used 80-90% onroad w 2-3 trips/ yr off-road use. I do want to maintain the smooth onroad ride of the JK.
Thoughts?
Old Sep 9, 2015 | 11:23 AM
Rock Krawler Suspension's Avatar
Former Vendor
Thoughts?
With that lift height you will maintain or increase drivability, with a quality kit, on the road with both mid and long arms. Either way, choose a good lift brand and I'm sure you will be happy
Old Sep 9, 2015 | 11:24 AM
Invest2m4's Avatar
JKs are actually mid-arm. You would not notice a difference with your setup. Your wallet would be lighter though. If you start getting into long travel coilovers, then there starts to be a benefit. I'm talking 14"+ of travel.
Biginboca's Avatar
My thought is you will be good with short arm. I don't see the need to spend that much on long arms for your uses and also don't see much benefit at 2.5" lift. Long arms really start to make sense on the JK when you are getting closer to 4" lifts and up.
Old Oct 1, 2015 | 07:22 PM
thzpcs's Avatar
Motostew has a really solid guide on doing lifts. You might want to take a look since it's pretty comprehensive.
Old Oct 1, 2015 | 07:31 PM
TheDirtman's Avatar
With what is offered out there in long arm "kits" you would just be wasting your money at that height.
