Low caster with spacers
Old Jan 9, 2013 | 05:31 AM
CCTEX84's Avatar
Default Low caster with spacers
My caster is at 3.1 for left and right is this normal for a jeep with only 1.75 spacers in front? I'm assuming I need to order lower control arms.
Old Jan 9, 2013 | 05:53 AM
cis911's Avatar
Did you check the castor yourself? or did you get the specs from the alignment shop? I'm asking because I tried checking it myself but the ground wasn't level
Old Jan 9, 2013 | 05:59 AM
cis911's Avatar
I had a 2.5" BB with 37s so I'm guessing my caster was less than what you have now. I didn't have adj control arms and it drove fine. But if you want to fine tune your caster/ better joints then I would go ahead and buy them
Old Jan 9, 2013 | 06:01 AM
CCTEX84's Avatar
I couldn't seem to match castor with an angle finder took it to the shop. I see guys with 2.5 lifts and 3 having low caster Didnt think coil spacers would affect it that much. Though I did drive a friends jeep and made me alot more confident with mine.
Old Jan 9, 2013 | 07:33 AM
SpicedCrusher's Avatar
My caster is at 2.5 and 2.9. It drives reasonably well, although I do get the flighty feel only around the 40-45 mph range. I'm assuming a set of LCA's would fix this problem. It's tolerable for now but will probably add LCA's at some point in the future.
Old Jan 9, 2013 | 07:34 AM
chris@offroadevolution's Avatar
Sponsoring Vendor
As you found out, spacers wont change it enough to worry about caster numbers
Old Jan 9, 2013 | 07:37 AM
CCTEX84's Avatar
Your right it is tolerable just slight flightiness with minor bump steer. Guess ill be looking into lca's plus play in drag link on my to do list
Old Jan 9, 2013 | 07:42 AM
Mschneid's Avatar
I don't understand how wheel spacers can change/effect caster, please explain.
Old Jan 9, 2013 | 08:00 AM
yo_marc's Avatar
They're actually referring to coil spring spacers.
Old Jan 9, 2013 | 08:08 AM
yo_marc's Avatar
I think it comes down to personal preferences. I ran 1.75" spacers for a while... it rode good. For me, it was hard to notice a difference, until I swapped back to stock. Stock just has a nice settled feeling to the steering and bump handling. It convinced me that if I were to lift at all, that I would want to correct front end geometry the best I could.
