Low-cost / Free mods that should be done?
Old 09-11-2014, 05:42 PM
  #4201
JCDriller's Avatar
$14. evap relocation.
The factory location. What were they thinking !?
(Google Pic)
Attachment 574814
4 clamps and 3 feet of 5/8 fuel hose. Above the rear diff.
Safe and sound.
Attachment 574816
What did you use to actually secure it up there? I want to move mine, but thought I needed a bracket of some kind.
Old 09-11-2014, 05:54 PM
  #4202
jkrubcon's Avatar
$14. evap relocation. The factory location. What were they thinking !? (Google Pic) <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=574814"/> 4 clamps and 3 feet of 5/8 fuel hose. Above the rear diff. Safe and sound. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=574816"/> .
Any chance you could please crawl under again and shoot us more pics at different angles? Thanks
Old 09-12-2014, 04:32 AM
  #4203
kaptkrappy's Avatar
It's a simple job. Just some basic hand tools and an hour of your time.
I read stangjeeper's thread https://www.jk-forum.com/forums/jk-w...y-cheap-72980/ and improvised a little here and there.
The only part that is difficult, is getting everything placed so that the E-brake cables don't rub on anything and that here is enough slack in them when the differential is at full droop.
Name:	Evap Relo 2 med.jpg
Old 09-12-2014, 09:22 AM
  #4204
Vladimer's Avatar
Originally Posted by HeyOk
Sometimes you just need a place to put your stuff. I'm always looking for a flat surface.
I use this to hold tools and as a work bench. Probably wouldn't hold up too well if you were to sit on it but it is surprisingly strong.
Some paracord is being used for the supports. Originally I was going to use cable but the paracord is easy to work with and doesn't rattle around when the shelf is folded up.
To help keep the bolt from ripping out of the wood, another piece of angle was used. It distributes the force over a much larger area and keeps the wood from splitting.
Added to the consolidated thread! https://www.jk-forum.com/forums/modi...ontier-309589/
Old 09-12-2014, 09:34 AM
  #4205
HeyOk's Avatar
Default My new burrito warmer!
I like to have a hot lunch after I have been wheeling for a few hours. The engine is making a lot of heat anyway, so why not use it?
At home, before a wheeling trip, I used to warm up a couple of burritos in the microwave and then wrap them in three layers of tin foil. Then I would wedge them on top of the alternator. They are kind of kept in place by the mounting hardware for the alternator, but on a couple of occasions, I did end up losing my lunch!
On another forum I saw how a guy with a WJ had taken a bread pan and fabricated a lid and a mount to hold it to the firewall.
Seemed like a good idea and I had just the thing to mount it to... a while back I made a mount to hold my ARB compressor to the brake booster, but wasn't using that any more because I had moved my compressor down by the lower radiator bracket... but that's a story for another post.
As I was saying, this is bread pan and I have made a lid for it from some aluminum sheet. There are two brass hinges screwed into it. The fancy wood trim you see is really just something for the wood screws to bit into as I didn't have any machine screws suitable for the hinges. I also made a wood handle for the lid. The lid is held down with a kitchen cabinet latch thing. There is some weather stripping around the edge of the lid to try and help keep the heat in and the dust/mud etc out.
Here you can see the temperature is 180 F after a run up to the top of Eagle mountain.
Mmm, lunch! This time it was a couple of samosas that I bought from Safeway.
Old 09-12-2014, 11:06 AM
  #4206
JJoosshh's Avatar
Originally Posted by pupps01
I cut out the rear "tool box", ditched the muffler and fitted a large compartment box.
It will serve as a second battery house as well as a bit of recovery gear.
How deep is the box with the muffler removed? Thanks.
Old 09-12-2014, 01:19 PM
  #4207
mpthompson84's Avatar
This mod made me crack up. The things that Jeepers come up with lol (great idea btw)
Old 09-14-2014, 06:35 PM
  #4208
casamtb's Avatar
Tapped 4 4.5w eagle eye LEDs to reverse wires in back. $15 and now I can see.
Old 09-14-2014, 06:42 PM
  #4209
deepjeep13's Avatar
Can you post a day light picture? Close up
Old 09-14-2014, 06:46 PM
  #4210
casamtb's Avatar
will do
Quick Reply: Low-cost / Free mods that should be done?
