Lower control arm questions
Old Feb 20, 2014 | 08:59 AM
  #41
Maertz's Avatar
Originally Posted by TheDirtman
Ballistic can make you what ever size aluminum arms you want. Just throw on whatever joints you want to run.
i debated that, but id rather do it my self. I might try and borrow a buddies aluminum welder to do mine, but I wouldnt be upset running steel by any means either...i can get either from my store for dirt cheap so that makes it hard for me to pay more to have someone do it when i can do it for less. not to derail but did you use steel or aluminum?
Old Feb 20, 2014 | 09:01 AM
  #42
TheDirtman's Avatar
I used 2"x.25" steel dom. With aluminum I would go solid 2" rod for lowers and no welder would be needed. Just drill and tap.
Old Feb 20, 2014 | 09:05 AM
  #43
Maertz's Avatar
yeah thats my main plan minus the uppers. everything else will be steel so far so i might not mess with the aluminum at all.
Old Feb 20, 2014 | 10:08 AM
  #44
Matthewd5's Avatar
Originally Posted by Maertz
the strength will be determined off of the od and wall thickness as well as the material/hardening. Most arms are stronger, but if your bending stockers I wouldnt try say a skyjacker. Personally if i had a aluminum setup for my welder id go aluminum. personally ive only ran a few different kind of control arms before making my own.
Ok
I understand the whole mild steel vs chromoly, but aluminum?
If I've already bent steel ones I wouldn't think if aluminum...
I have access to a friends shop, he has a lift and tons of welding gear and several lathe's, he mostly makes custom drive shafts
Old Feb 20, 2014 | 10:20 AM
  #45
TheDirtman's Avatar
7075 aluminum is roughly the same strength as 1020-1026 alloy
Old Feb 20, 2014 | 10:51 AM
  #46
Maertz's Avatar
Originally Posted by Matthewd5
Ok
aluminum can gall and if i were to do it i would probably go slightly thicker than i would if i used dom. Even at that though you could go to control arms weighing 5lbs a pop compared to 15lbs a pop. Not a huge weight savings by any means, but can be done safely id say, even on the heavy jks.
