Lowest preasure without beadlocks?
Old Jul 5, 2012 | 06:20 AM
Boater's Avatar
Default Lowest preasure without beadlocks?
I'm Running 20x10 wheels with 40x15.5 toyo mt's. Without a beadlock, what is the lowest psi I can run withount losing a bead? Thanks in advance.
Old Jul 5, 2012 | 06:32 AM
wayoflife's Avatar
JK-Forum Founder
being that you're running 40x15.50 toyo's on 10" wide wheels, i personally would be willing to run them at about 10 psi. still, without bead locks, you can roll a bead given the right circumstances.
Old Jul 5, 2012 | 06:39 AM
Boater's Avatar
Thats pretty low. I was thinking 15 at the lowest, but you would know better than myself. Thanks for the imput!
Old Jul 5, 2012 | 07:01 AM
wayoflife's Avatar
JK-Forum Founder
will a lesser tire, i probably wouldn't go lower but, the toyo's have really thick sidewalls and it'll hold up to the lower psi better.
Old Jul 5, 2012 | 08:12 AM
Tonka_yellow's Avatar
I would run 10psi if you have a spare. 15 if you don't
Old Jul 5, 2012 | 08:18 AM
Biggy's Avatar
I run my 37 toyos at 9-10 psi. No problems so far. As Wol said the sidewalls are stiff and you have to air low to get some flex out of them.
Old Jul 5, 2012 | 08:21 AM
Boater's Avatar
Have a spair so I can live on the edge!
Old Jul 5, 2012 | 10:13 AM
albg's Avatar
Keep in mind that you can still spin the tire on the wheel at that pressure pretty easily thus throwing off the balance. I would mark the tire and rim so you can tell after a trip.
