Lubelocker diff gasket
Old Oct 3, 2008 | 08:29 AM
Mossyoakman3006's Avatar
Default Lubelocker diff gasket
So I am thinking of changing my front and rear diff fluids and gaskets. I was gonna go with lubelocker reuseable gaskets and royal purple gear oil. Has anyone done this, is there anything that I should know ahead of time?
Old Oct 3, 2008 | 08:48 AM
tgrt's Avatar
Former Vendor
They work great for the first few times you have to remove the cover. I had mine on the front after developing a leak after banging the differential on the rock (I guess it broke the RTV seal). Unfortunately, it wore out after a few times of removing the cover during my gear installation. After everything else I spent I didn't want to spend more.
Old Oct 3, 2008 | 11:36 AM
dyolfknip's Avatar
I picked up a Solid diff cover from a forum member with the LL attached. Threw it on and good to go.
Old Oct 3, 2008 | 11:49 AM
bly109's Avatar
I m happy with our lube lockers so far. I hit the front a few times pretty hard and no leaks yet. But I havent taken them off and tried to reuse them yet
Old Oct 3, 2008 | 12:39 PM
tgrt's Avatar
Former Vendor
They take a hit well with no leaking. Mine did anyway. They flatten out after removing them a few times and then no longer seal well. This is not a knock on the product, because the manufacturer states right out to replace them after you've removed them.
Old Oct 3, 2008 | 12:47 PM
bly109's Avatar
Thats kinda what I thought would happen. I didnt think they would last more then one or two uses without flattenning out. Thanks for confirming this Tony. I'll just plan on replacing them when I regear next year.
Old Oct 3, 2008 | 02:48 PM
seer1's Avatar
Yep, you can get three or four out of them (don't ask how i know) so it comes out a few dollars more than a tube of RTV. Of course once you through in time and clean up factor then I think you come out a bit ahead.
Old Oct 3, 2008 | 05:36 PM
Strong Bad's Avatar
I have had mine about 3 months. Plenty of use and no problems. (Knock on wood)
Old Oct 3, 2008 | 06:13 PM
tgrt's Avatar
Former Vendor
The regearing is what was the killer. Take it off, set the gears up, put it back on, correct, and repeat. The shop had to do that a few times, because they were trying to correct the noise from the gears -- that's a different discussion though. The poor Lube Locker didn't stand a chance.
Old Oct 3, 2008 | 06:27 PM
jeepsanddrums's Avatar
I would consider using a less expensive gear oil if you plan on doing water crossings. I put royal purple in my diffs about a month ago. Since then I have done a couple of water crossings and am wandering if water may have gotten into my diffs. I have seen some pictures of milky gear oil and it isn't pretty.
