Lurching when getting on and off the gas?
I have something similar as well. Does it make kind of a grinding sound during takeoff, like a metal on metal rotating sound?
Does it do it everytime you take off or just when you first take off when it's cold/been sitting for a while?
I thought it might be the diffs/ front ds and when those were both swapped it stayed the same.
I'm down to the transfer case and rear ds with mine. I'm going to replace my rear ds first and see if that does the trick. If not I will find myself at the dealer once again...
No sound during take off at all. I only experience the bucking and clunking sound I the rear. I can almost always reproduce it. I took my front DS out last year to troubleshot and it still did it. Has to be issue with drive train toward the rear.
I have a 4" lift and running 35s. I've noticed a little noise most likely from the drive shaft angle. My caster is 0 but my CAs, track bar and new drag link kit will be here in a couple days. I think just getting all the geometries in order will do the trick.
