maybe a dumb question
Old Nov 4, 2009 | 09:26 AM
the_cuse420's Avatar
Default maybe a dumb question
can you regear your transfer-case i feel like a real jackass asking the question.
Old Nov 4, 2009 | 09:32 AM
PeeJ_Zip's Avatar
That is not a dump question at all. Currently - no. But I am sure there will eventually be options for that. When Jeep offered the Rubicon transfer case manufactures seemed to stop offering re-gearing kits. They were available for ealier years pre-Rubicon.
Best current solution: Get a Rubicon Case, or go big with at Atlas.
Old Nov 4, 2009 | 09:36 AM
RedneckJeep's Avatar
You can get an aftermarket case like an Atlas that CAN be regeared. BUt as stated, as of now, not the stocker. You can get a case from a Rubi and it will be different than an X or Sahara. I think the Rubi is like 4 to 1 and the others are 2.7 to 1 or somethin like that....I forget.
Old Nov 4, 2009 | 09:38 AM
Default so find a rubicon
get a rubicon transfer-case is my best bet
Old Nov 4, 2009 | 12:06 PM
nikbass's Avatar
4-1 is right on the Rubi Tcase. Doesn't help your mileage but if your looking for slow and steady it will get the job done.
Old Nov 4, 2009 | 12:10 PM
Are you really talkin about MILEAGE in 4 LO?
Old Nov 4, 2009 | 01:31 PM
stlfan06's Avatar
I think we found him....
Old Nov 4, 2009 | 01:34 PM
guinnessisgood's Avatar
Idling down the trail in 4 lo alone hurts your mileage more then 4 to 1 does....
Old Nov 4, 2009 | 01:36 PM
TheonlyREDhead 2008 JK's Avatar
Is there a real benefit for the switch?
Old Nov 4, 2009 | 01:59 PM
PeeJ_Zip's Avatar
Yes and no. If you mainly wheel in sand, mud, fire roads or blasting around the 2.7:1 X case is better.
If you like to crawl on rocks and do technical stuff that could put you on your roof easy then the Rubicon 4:1 is better.
I blasted the sand dunes at Pismo Beach with my X case, spend a lot of time doing hill climbs in 3rd gear, 4 low. I guess with the Rubicon case it would have been 5th.
