Metalcloak Thread
Old 11-18-2014, 04:38 PM
  #1861
Invest2m4's Avatar
Originally Posted by sjd78
I'm more concerned with the height then the capacity
The 6 tons are way taller than 3 tons and I feel far safer. I've done everything under them from axle swaps, t case swaps, to cutting and welding. Honestly, a standard floor jack won't even get the jeep high enough to exceed their height.
Old 11-19-2014, 01:13 AM
  #1862
14Sport's Avatar
6s for me. I already had 3s but got 6s just to make sure.
Old 11-19-2014, 05:09 AM
  #1863
sjd78's Avatar
Awesome! Thanks guys, that's what I needed to know. 6 ton it is.
Old 11-24-2014, 12:33 AM
  #1864
K9wells's Avatar
Does anyone know the formula to use to accurately adjust my upper control arms on the rear axle?
Old 11-24-2014, 02:19 AM
  #1865
14Sport's Avatar
There's no formula. You set your pinion angle depending on which drive shaft you have.
ID:	585491   Click image for larger version
Old 11-24-2014, 07:48 AM
  #1866
K9wells's Avatar
Yes i have a double cardon driveshaft but need to adjust it just was trying to figure it out the shaft is at z degree the flange is at y degree and my uppers are currently x long how much do I need to extend them for ride height to match the degrees.
Old 11-24-2014, 07:57 AM
  #1867
TheDirtman's Avatar
Just adjust it so that the driveshaft is almost straight with the pinion with just a slight down angle at the pinion. There are too many variables for an exact measurement that works for everyone.
Old 11-24-2014, 08:19 AM
  #1868
14Sport's Avatar
IIRC, when I did mine I just put a floor jack under the front of the dif, disconnected the uppers, used the jack to position the angle, and then adjusted the arms to fit the holes, making sure they were the same length.
Old 11-27-2014, 03:33 PM
  #1869
TaylarsJK's Avatar
Is anyone here running Rancho RS9000 shocks with their Metalcloak springs? I'm getting ready to pull the trigger on a set of shocks but just wanted to hear some personal experience from some folks
Old 11-27-2014, 04:42 PM
  #1870
JE8154's Avatar
They're too short. Check travel numbers and extended/collapsed lengths.
Quick Reply: Metalcloak Thread
