Metalcloak Thread
#1911
So... was I supposed to remove the coil spring isolators when I installed the lift? I left in the fronts and rears to diminish any potential banging. All four springs are evenly seated up top, with no apparent deflection of the isolators.
#1912
#1914
No leave the rubber isolators in. I am talking about he axle end.
#1916
Did rear control arms come with your lift? It looks like that axle has been moved back quite a bit
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=595822"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=595823"/> as you can see my rears are curved. my front springs are not. isn't this due to the slight rotation of the axle for the increase angle of the driveshaft?
#1920
A couple of different conversations here. With regards to my front passenger spring... the lowers are the same length, the axle is squared/centered, caster is 4.5° , springs are seated appropriately top and bottom -can I assume at this point that a replacement spring is necessary? If so, do both fronts need to be replaced as a set (between 9-10K miles since install)?
