Metalcloak Thread
Old May 4, 2015 | 05:34 AM
  #2121
14Sport's Avatar
When I bought my MC kit the arms came preset for 3.5" coils with no length given for 2.5". That may have changed though.
Old May 4, 2015 | 05:35 AM
  #2122
bryanwithawhy's Avatar
That sounds correct.
Old May 4, 2015 | 05:36 AM
  #2123
DunnyBunny's Avatar
JK-Forum Ambassador
I just installed mine and looked up their instructions to check lengths and they are the same for 2.5-3.5". All 8 arms
Old May 4, 2015 | 05:42 AM
  #2124
Either way when they open in an hours and a half I'll just call and get the correct measurement and I'll change them after work. Idk how I measured so far off. I remember the track bar being pre-set but not the arms
Old May 4, 2015 | 05:43 AM
  #2125
DunnyBunny's Avatar
JK-Forum Ambassador
Originally Posted by bryanwithawhy
They actually seem to be bowing towards the frame btw. They also seem of have spun and are sitting funny in the cups
Have the rubber spring dampeners (or are they isolators) on top of the coils?
Old May 4, 2015 | 06:00 AM
  #2126
14Sport's Avatar
I suppose if you're doing both lowers and uppers you can get away with that, stretching it a bit. But for just lowers you are stuck dealing with fixed length uppers and your options are greatly reduced.
Old May 4, 2015 | 07:47 AM
  #2127
DunnyBunny's Avatar
JK-Forum Ambassador
Typically 23" is a good starting point for lowers on 2.5" lift.
Actually if you look at the instructions again for all 8 their starting upper setting is same as stock I believe.
Old May 4, 2015 | 11:05 AM
  #2128
14Sport's Avatar
I just don't buy into the whole "set the uppers at factory length" thing. Why even buy adjustable then? Just for the added flex of the joint? It would be cheaper for MC to manufacture fixed arms for the uppers in that case. If you think about it, when you lift your rig you lose wheel base. The lowers can put some of that back as well as square the axle to the frame. Then use the uppers to find the correct balance of caster/pinion for your rig. That's how I did mine and I have not had any handling issues. But to each his own, I am certainly no expert but I know what worked for me.
Old May 4, 2015 | 11:14 AM
  #2129
DunnyBunny's Avatar
JK-Forum Ambassador
Worked for me to. I didn't go with the lengths they have in their instructions. They are set a little longer but not much.
Old May 4, 2015 | 11:20 AM
  #2130
tae73's Avatar
Dang I opened my email this morning only to find there was free shipping over the weekend. I called to see if they would extend a day for me and no luck so will have to swallow the shipping cost or wait for the next one.
