Metalcloak Thread
Old 12-05-2016, 11:23 AM
  #2561
JK_Marilyn's Avatar
I bought a '13 JKU that came with a new Rough Country 3.5" suspension lift on it. After spending some time trying to figure out what components needed to be upgraded to get a decent ride quality, i found the answer to be "everything."
Went with the MetalCloak 3.5" kit and couldn't be happier. Softer ride, better handling, smoother cornering, better flex - it's a completely new Jeep.
Sometimes you have to taste the sour to appreciate the sweet.
Old 12-05-2016, 01:09 PM
  #2562
Ripa777's Avatar
Originally Posted by JK_Marilyn
I bought a '13 JKU that came with a new Rough Country 3.5" suspension lift on it. After spending some time trying to figure out what components needed to be upgraded to get a decent ride quality, i found the answer to be "everything." Went with the MetalCloak 3.5" kit and couldn't be happier. Softer ride, better handling, smoother cornering, better flex - it's a completely new Jeep. Sometimes you have to taste the sour to appreciate the sweet.
Agree. It's such an incredible diff!!!! Love drivin my JK once that MC was installed!!!
Old 12-06-2016, 01:00 PM
  #2563
rfr002's Avatar
Has anybody heard of anyone bending the MC arms? 3/16" wall seems a little thin on a heavy JK to me.
Old 12-06-2016, 01:16 PM
  #2564
Invest2m4's Avatar
They can bend and I have bent one back when I ran their kit. It is pretty unlikely and they replace it as soon as you send a picture. Just about any arm out there is around the same strength, unless you run something like a solid 7075 link that a couple places make.
To be clear, I put my Jeep through a very high level of abuse. If I recall, it was a 4ft drop off a ledge landing on one rear control arm onto a pointed rock. Honestly, I could have left it and been fine, but was about the sell the kit and decided it was best to warranty out.
Old 12-10-2016, 11:41 AM
  #2565
dozer311's Avatar
Default wheels to fit MC GC
what back spacing will work with the 2.5 and 3.5 GC?
Old 12-10-2016, 12:06 PM
  #2566
Monte417's Avatar
The lift your running has nothing to do with backspacing. That's is dependent on what size tire you want to run. You should read up on what different suspension compenents do before diving into a suspension build
Old 12-10-2016, 01:32 PM
  #2567
dozer311's Avatar
I guess that makes perfect sense... keep in mind i have nothing yet, still stock. either getting the 2.5 or 3.5 GC and want to select tires and wheels next but which do you select first? I want to run 35's on a 17" wheel. i just like the look of 17's. help would be apprecated.
Old 12-10-2016, 02:03 PM
  #2568
nthinuf's Avatar
FAQ's and Thoughts On Lifts are stuck right to the top of this Modified area. Both will give some background on backspacing and tire size vs lift height. Also take your choice of stock vs chopped vs flat flares into account. (and whether you are going with the 6paks...)
But the general recommendation for 35x12.50's is a 4.5" backspace. (roughly 1.75" further out than stock rims.)
Old 12-10-2016, 02:36 PM
  #2569
dozer311's Avatar
Great info,many thanks. Ok, back to the MC thread.
Old 12-11-2016, 05:16 AM
  #2570
Jahamm88's Avatar
Originally Posted by Matt2105
Anyone running their overland kit? I was originally planning to go with their true dual rate kit but I'm thinking the overland is better for my style of driving
I'm running some form of it, 2.5" 2dr coils on a 4 door with brackets which has netted me around 2". I may swap coils up to 4dr ones since I've added armor and a bumper and winch is in the future. No complaints but will eventually replace brackets with UCAs. I'm still on the fence if I should have just gone dual rate to begin with. Ride quality is great but a lot of that comes from the fox2.0 resi shocks
Quick Reply: Metalcloak Thread
