Metalcloak Thread
#722
#723
The toe is just the tires and if they point towards each other or not, I've not seen the toe setting adjusted by shifting the axle to the side unless you manage to pull tie rod threads when you're moving the axle (quite unlikely).
Sent from my DROID4 using Tapatalk
#724
#728
Caster is 4.2* from the factory. As far as recentering your steering wheel, it's really easy and not worth the $100. Just loosen the 2 nuts on your drag link turnbuckle and rotate the turnbuckle up to go left or down to go right with the steering wheel. Retighten and test drive. May need to tweak it some more.
#729
