Mid-length Stock Bumper help.
Old Jul 14, 2009 | 06:59 PM
abock33's Avatar
Default Mid-length Stock Bumper help.
So I'm going to chop my stock bumper to mid length but I'm not really a fan of the rivets. Has anyone tried to plastic weld a mid-length bumper? Would it hold? I like the look of Sharkbite's bumper/winch combo but I want a mid length bumper. Thanks.
here's his set up
Old Jul 14, 2009 | 08:50 PM
So_Cal_Tay_12's Avatar
Not a mid width but plastic welding nonetheless, this thing is bulletproof, better than stock, seriously, and you cant tell the difference between the factory lights and mine
Old Jul 14, 2009 | 11:38 PM
TINMAN080's Avatar
Check search feature under stubbie bumper, a couple of guys have used soldering irons to melt the caps on, I'm better with a rivet gun over a soldering iron....
Old Jul 15, 2009 | 05:46 AM
abock33's Avatar
All I saw were stubbies that were welded not mid-lengths. That's why I was wondering if it was possible to weld a mid-length.
Old Jul 15, 2009 | 06:33 AM
highergr0und's Avatar
I just did mine with rivets, but I think the welding would work with the way it sits in there. I wish I would've taken pics, but the end pieces that you put back on really have a lot of structure and not much weight. It literally fits in like a sleeve with a U shape so you'd end up building up most of the strength from the inside where you have a lot of material to spare and more or less seal it off on the outside.
Old Jul 15, 2009 | 02:21 PM
abock33's Avatar
Is there a reason you cut yours not parallel to the crush can bump. I've seen alot like that.
Old Jul 15, 2009 | 03:16 PM
Geeper4x4's Avatar
The reason : The nuts on the front of the plastic allow you to reattach the plastic bumper to the metal bumper. If you cut them straight you loose the attachment points.
