MidWest - St. Louis Metro - 2013 JKU Sport regear questions
Re-gear front and rear differentials w/4.56 gears and Eaton E-lockers
including wiring lockers and installing switches
1.00 YK D30-JK YUKON MASTER OVERHAUL KITS GIVE YOU 280.78
1.00 YG D30SR-456JK RING & PINION 235.00
1.00 EAT19819 E-LOCKER DANA 30 951.20
1.00 LLR-D030 LUBELOCKER DANA 30 21.95
2.00 75W140 BULK 75W140 SYTH GEAR OIL 25.98
1.00 YK D44-JK-STD YUKON MASTER OVERHAUL KITS GIVE YOU 356.08
1.00 YG D44JK-456RUB D44 4.56 THICK R&P 260.00
1.00 EAT19695 EATON E-LOCKER DANA 44 30SPL 1010.42
1.00 LLR-D044 LUBELOCKER DANA 44 21.95
Labor : $1,724.31
Parts : $3,189.34
Sublet : $0.00
$0.00
Supply Charges :
Other Fees :
$49.91
Subtotal : $4,963.56
Sales Tax : $236.85
Total : $5,200.41
Paid : $0.00
Due : $5,200.41
Signature X
this is the latest quote. i think i am just going to try and buy the locker and gears myself and see if i can find a shop to install them
Labor : $1,724.31
Parts : $3,189.34
Sublet : $0.00
$0.00
Supply Charges :
Other Fees :
$49.91
Sales Tax : $236.85
Total : $5,200.41
Paid : $0.00
Due : $5,200.41
Signature X
I just bout front and rear 5.13s with master install kits and a rear Eaton e locker 4 pin for 2k. Check out Northridge 4x4 and use the JKFORUM coupon code. Free shipping and 20% off
Sent from my SM-N900V using Tapatalk
Good call.
From just a quick yahoo search:
EAT19819 772.99 - 4WD
EAT19695 819.99 - Jegs
Fr/Rr 4.56 and Master install kits 599.99 - Northridge
+ 76.00 in fluids and lubelockers
= appx $2269 in parts.
Be sure to ask about the shop policy regarding customer supplied parts. Some shops will not install, or will charge differently, or will warrant differently if they do not provide.
I had axle boy swap out some gears in some rubi axles in 2011 and it ran right at $1700 for the gears, install kits, and labor. Parts list seems a bit high, I would think more like $2700 for parts and labor is quite high. The difference may be the extra time for the wireing of the the lockers and the switches.
I'm still in the camp of buying whole axles. Here is my example: I bought front and rear Rubi axles off a 2012, with under 15k miles. Axles were already geared to 4.88, rear axle had chromo shafts, arb diff cover, and diff skid. Front axle was sleeved, gusseted, Synergy ball joints, RCV axle shafts, currie coil buckets, arb diff cover, etc.
So two locked and fully built D44s for $4k. Net cost after selling my axles is $2500. No labor cost as it is super easy to swap axles.
Hey Invest, that sounds awesome but the issue is there aren't a whole lot of great deals like that for axles with everything already included! I have been looking all over for a decent set of axles with no luck.
I'm actually thinking about abandoning it all together! I just don't know what to do next!
I don't wheel that often but will more and more so want to start building the right setup.
On my list of mods to-do:
- 35" trail graps (switching out my 33" terra graps)
- 4.56 gears
- eaton lockers (new 4pin)
- on board air
- axle strengthening (shafts / truss / gussets)
- new hood ( power dome / aev / rk sport / rugged ridge)
- Bushwacker flares
- rear tire carrier (teraflex / ace pro series / PSC brawler II / 10th Anniv. W/ AEV carrier)
Any suggestions on what I should do first? Should I go with gears/lockers? Or should I wait for new axles or just put it off till next year? I only have about $3000 to spend till later this year
- 4.56 gears
- on board air
- Bushwacker flares
