Mileage drop with bumper
Old May 25, 2010 | 04:38 PM
Crasher's Avatar
Default Mileage drop with bumper
While looking up some reviews on the Smittybilt XRC front bumper a few said they lost 2 mpg. Is this common or a fluke? It does change the air flow, but I didn't think that much.
Old May 25, 2010 | 04:57 PM
Serg5000's Avatar
Two MPG shouldn't matter. I'm not sure why anyone would worry about such a little amount. Just remember, the jeeps are built per a spec. Then, we go and change all kinds of things. And wile doing so, we add a shitload of weight. Something has to give. In our case that would be fuel milage.
Old May 25, 2010 | 05:30 PM
Crasher's Avatar
I don't much care what the mileage is. It won't affect what I do to mine. In the last month, I bought the Rubi, spent $4800 on "Stuff" with bumpers and winch next on the list when I decide which ones. Fuel cost is the least of my concerns. I just thought that was quite a mpg change for a bumper. If that's the case, it would be my challenge (if I was a manufacturer) to build one that made the most of air flow and still do what we want it to.
Old May 25, 2010 | 05:36 PM
jasonG's Avatar
wait = less fuel efficiency sucks but .......
Old May 25, 2010 | 06:31 PM
Weeds's Avatar
My winch and bumper did not change my mileage. Treks bumper 65 lbs. Warn 9.5ti 89 lbs. Check your weights before you buy. A smittybilt winch weighs somewhere around 125 lbs.
Old May 26, 2010 | 04:16 AM
JPop's Avatar
You would need a lot more than a bumper to lose 2mpgs. If it's not rotating or sprung only a nominal amount of fuel mileage will be lost with weight unless it severely changes the aerodynamics of what is already a barn on wheels.
Old May 26, 2010 | 06:38 AM
RevyJKU08's Avatar
2 MPG seems high..lost about 1/2 MPG with addition of front and rear bumper and winch. Probably added close to 300-350lbs of weight, so the little 3.8L works a little harder to move.
I personally feel the key to the MPG loss is the removal of the stock plastic air dam.
Old May 26, 2010 | 07:08 AM
Kasper's Avatar
Sounds like a load of BS, I added a Smittybilt SRC and didn't notice any change from that.
My mpg is all over the place....all depends on wind and rpm's. For me to pinpoint any mpg change on a mod is almost impossible.
Old Mar 28, 2012 | 11:46 AM
AgnisBegone's Avatar
Originally Posted by chip80
Anything that increases wind turbulance under the vehicle will negatively affect MPG. I've been told that the air deflector under the stock front bumber is designed to pull more air through the radiator and smooth air flow under the vehicle, if this is true then removing it to install an aftermarket bumper could negatively affect MPG.
Hi JKFreak- how do you like, or what do you think of your RR front bumper? Is it holding up well? i was thinking of getting on but i've read a few threads where the powder coat started peeling off. Are you experiencing this? So, for me it's between RR or the new Smitty XRC MOD. (which is on back order)Any feedbackwould be helpful .thanx
Old Mar 28, 2012 | 11:55 AM
Runewolf1973's Avatar
Sorry to cut in like this but... I have the Rugged Ridge front and rear bumpers. They are holding up great. No issues with the powder coat or anything. I like em a lot. IMO they are one of the best bang for buck bumpers out there.
