Mirror relocation brackets.
Old Jun 4, 2008 | 09:36 AM
Joker92's Avatar
Default Mirror relocation brackets.
Does anyone have pics of their JK with the side mirror relocation brackets installed?
Your thoughts? I heard that you do loose some visability with them but not too bad.
How do you get the mirrors off without scratching the paint?
Also, does moving the mirrors and capping the holes stop the probelm of after washing the Jeep, having water slowly drain from the mirrors, leaving watermarks down the doors?
Old Jun 4, 2008 | 09:46 AM
whtIwrk4's Avatar
I have the Rugged Ridge relocation brackets. They are easy to install and fairly priced. You lose some visibility on the passenger side mirror when the door is on, but you get used to it.
Old Jun 4, 2008 | 09:52 AM
Offroadme's Avatar
lets see some pictures.... i made some brackets for some mirrors i had lying around the garage.. but i went to get the relocation brackets make life easier, def need them before it gets really warm out...
Old Jun 4, 2008 | 10:53 AM
Reiper's Avatar
I have the RR brackets I'll try and post pictures if I can't I'll put them on My Project JK, also there is a thread on here some where with pictures
Old Jun 4, 2008 | 10:54 AM
westchester's Avatar
Warrior brackets IMO work alot better than the Rugged Ridge ones. Do a search for "Mirror Brackets" and you'll find many stories & posts and after reading these, ask away any questions. Warrior visability is good. The stock mirrors are taken off by removing the torx screw on the underside. Bought on http://www.quadratec.com/products/12110_71.htm
Old Jun 4, 2008 | 11:10 AM
The SRC's Avatar
I've got the Rugged Ridge brackets. The driver side mirror is fine with the doors on, I lose about 3/4 of an inch on the inside of the mirror but visability is still fine. As for the passanger side.... I get about 2 inches of mirror view with doors on (with a generous torso lean toward the passanger seat). I put one of those stick on mirrors which has helped some. Regardless, I never really trusted the passenger side mirror in the first place. I prefer the old look back method. They both work great with the doors off. Installation took some finagling (sp?) due to thread issues.
Here is a pic for comparison between the Warrior above and the RR. I've never seen the Warrior Brackets in person but they do look like they give better visability by Westchester's pic.
Old Jun 4, 2008 | 11:16 AM
Reiper's Avatar
Here are the pictures........ I hope .... well theres one can't figure out how to post multiple pics
Old Jun 4, 2008 | 11:25 AM
Offroadme's Avatar
i hate to be that pain in the ass person but lets see some close up pics of these baby's i don't know which ones to get.... any mirror shake... that is my biggest concern.. if im going to spend some money on getting them and they are going to shake im just going to make my own. any complaints besides the pass mirror
Old Jun 4, 2008 | 11:34 AM
Warrior brackets do cause the mirrors to shake excessively, but it is easily cured (2 minute fix) with a strip of duct tape acting as a washer between the plastic mirror surround and the metal bracket (I'll write more if anyone needs details). Suggest you use search function for the Rugged Ridge feedback on other threads.
Old Jun 4, 2008 | 11:51 AM
The SRC's Avatar
The RR brackets come with a pad that goes between the bracket and the body. No shaking or vibrating at all. I'm sure there are a number of materials around the house that can work just as well. Don't have any close ups as of now. I'm presently at work with no camera (working real hard if you can't tell!).
I'm sure you have already seen it but just in case..
Here is a link to Quadratec which has a descent close up
