Mirror Relocator Kit
Old Feb 9, 2012 | 10:54 AM
hkchase2007's Avatar
Default Mirror Relocator Kit
So...I went to install the mirror relocators the other day. While following the directions, I tried to remove the OEM mirror from its OEM mounting bracket. It was a no-go. The directions said that after removing the bolt, one would have to work it side-to-side. As much as I do this, it seems as though the mirror and the mounting piece is a single unit. Does any one know or can offer any suggestions, other that bashing it with a hammer? Thanks
Old Feb 9, 2012 | 10:56 AM
ac1brooks's Avatar
It's in there snug. I had to stand on a ladder while twisting & pulling up on it.
Old Feb 9, 2012 | 12:06 PM
Tonka_yellow's Avatar
I thread a bolt in there and put them in a vise. Then gave it Hell with a rubber hammer
Old Feb 9, 2012 | 12:13 PM
Hook-Em's Avatar
Spray some penetrating lubricant into the socket from on top. Let is sit for maybe 5 minutes. Start the screw into the threads on the mirror head so there is a gap between the bottom of the screw head and the bottom of the mirror arm. tap the screw head with a hammer or mallet. It worked like a charm for me. Also once the mirror head is out, spray it with some teflon or white lithium grease to keep if from seizing in the future.
Old Feb 9, 2012 | 12:14 PM
Cold's Avatar
I threaded the bolt back in and gave it a few good whacks with the trusty rubber hammer. Its in there really good.
Old Feb 9, 2012 | 12:20 PM
Hook-Em's Avatar
I did the same thing with mine. It wasn't until I sprayed penetrating lubricant into the socket that I got any results. After that it popped out easily.
Old Feb 10, 2012 | 06:48 AM
Thanks y'all.
Old Feb 10, 2012 | 06:51 AM
Hook-Em's Avatar
Thanks y'all.
Did you get it?
Old Feb 10, 2012 | 04:06 PM
Originally Posted by Hook-Em
Did you get it?
Not yet...It was pretty cold and rainy most of the day. Just before sunset I put the penetrating oil on it, gave it 2-3 "taps". No love, thinking about using a different type of hammer...maybe a Jack-hammer
Old Feb 12, 2012 | 05:14 PM
TheTOMizzle's Avatar
What year Jeep do you have? I had a set of relocation brackets. Loved them. But I cannot use them on my 2011 Shara Unlimited. My mirrors have an electric defrost. So I am assuming they are hard wired. Someone please correct me if I'm wrong. I'd love to use my old brackets again...
