misting system
Old Jun 29, 2016 | 05:07 AM
The Black Jeep's Avatar
Originally Posted by Cutman
Spiderweb Shade is a big help. When it's that hot, not being in the direct sun is huge. Makes upper 90's almost tolerable. Best $90 I've ever spent.
I have a safari top that I use I know that helps but in 110° heat all air feels like a blow dryer blowing on you shade or not
Everyone who ever takes the top and doors off knows the air moves from the back to the front and out the front sides imagine if you had a couple mist nozzles mounted to the rear bar and it dropped that temp 15 degrees
Old Jun 29, 2016 | 06:04 AM
Huk's Avatar
Huk
Look up garden irrigation systems. I have used misters with 20 psi that give a great mist. They suposidly use 3/4 gallon per hour.
Dripworks is one company. Good luck.
Old Jun 29, 2016 | 07:54 AM
So they mist not drip though?
That was my concern with using a drip system 3/4 per hour would be doable
Old Jun 30, 2016 | 08:26 AM
Huk's Avatar
Huk
Correct. Very fine mist. Their site has pics and a couple different options. There are several companies with very similar products.
Just type mist into their search or you may only see the drip versions.
Old Jun 30, 2016 | 03:32 PM
Mr. Incredible's Avatar
That's the problem I've had in the past with any misting system. If it doesn't have good psi, it drips and doesn't get the real fine spray.
Old Jun 30, 2016 | 04:17 PM
bbolander's Avatar
I just saw mister nozzles at Ace Hardware here in Southern Nevada. In the landscape irrigation department.
Old Jun 30, 2016 | 07:21 PM
Sweet thanks guys
Anyone have ideas for a cheap pump
Also tank
The one write up I saw the guy used a large washer fluid reservoir from an suv and just used those pumps that were included
Any ideas
Old Jun 30, 2016 | 07:53 PM
Cutman's Avatar
If you get some good ideas going, I'm willing to try. Being in TN, the shade helps a lot. You still have to squeegee off the humidity though.
Old Jul 1, 2016 | 10:09 AM
Which is where misters won't really help, they'll just get you wetter. Evaporation is the key and that's what causes the drop in temps. Out here in Phoenix, misting systems do wonders until monsoon season when our humidity goes up. They still help a bit because it's SO damn hot, but you'll get wet more than cool.
Aeromist makes a small 150 psi pump that works on 110v, it's a good size too and only pulls 1 amp:
https://www.aeromist.com/misting-pum...-120-volt.html
Old Jul 2, 2016 | 12:33 PM
The 110 volt and the $230 price tag makes that out of my league as I would still need to get an inverter to run it
