Modified Shrockworks Stubby
Old Feb 21, 2009 | 02:18 PM
Strong Bad's Avatar
Default Modified Shrockworks Stubby
I really like the Schrockworks Stubby bumper so I decided to pull the trigger. Called Eric at Screamin' Lizard and he went out of his way to get it to me ASAP. It was only after it arrived that I realized that the fairlead opening was offset from center for the Warn Power Plant. Since I have a MileMarker Hydraulic this posed a problem. I cut out the original opening, welded in a new plate and cut out the new "centered" fairlead opening.
What do ya think?
Old Feb 21, 2009 | 02:26 PM
blockrockin's Avatar
looks good.. you did a nice job. great bumper ! what did you use to get in their and tighten up your lights mounted on your bumper ? i am having a hard time finding something small enough to fit in their and tighten the bolt for the lights .
Old Feb 21, 2009 | 02:27 PM
Strong Bad's Avatar
Glad to hear they took care of you as well. I was very impressed with their customer service.
Old Feb 21, 2009 | 02:28 PM
Strong Bad's Avatar
Thanks. It obviously took a little extra time, but I think it was worth it.
Old Feb 21, 2009 | 02:30 PM
Strong Bad's Avatar
I had to keep flipping my open ended wrench to get the lights tight.
Old Feb 21, 2009 | 03:11 PM
jfaulk's Avatar
Which finish is that on the bumper? Looks like line-x or similar.
Old Feb 21, 2009 | 03:22 PM
Strong Bad's Avatar
Herculiner
Old Feb 24, 2009 | 04:45 AM
ToyFamily's Avatar
Former Vendor
Glad you are happy with it. The winch fairlead hole and mounting is offset for most all winches, not just the power plant. The motor side of the winch is *almost* always longer than the clutch side.
Nick
Old Feb 24, 2009 | 04:59 PM
Strong Bad's Avatar
Nick
I completely understand the thought process for the offsetting the fairlead, it just wasn't ideal for my set up. So rather than settle for a lesser bumper, I made it fit. Also thought it might give others in a similar situation some options.
Old Feb 27, 2009 | 01:36 PM
ToyFamily's Avatar
Former Vendor
Well, good job, if they didn't design it I don't think many would notice.
Nick
