Sway Bar Torque
Old Feb 27, 2009 | 11:11 AM
jmat1980's Avatar
Default Sway Bar Torque
Im adding the rugged ridge front skid which uses the bolts that hold the sway bar up. Does anyone know what the torque specs are for the 4 bolts (2 on ea side) that hold the sway bar up??
Thanks
Old Feb 27, 2009 | 12:10 PM
chuck45's Avatar
Thanks
If nobody responds with a specific torque figure from a factory manual you can always go to a site like this:
http://www.machinetoolhelp.com/Repairing/bolt-torque-chart.html
and get a generic torque rating based on the bolt size.
A little planning ahead can help too. If I think torqueing to spec is going to be critical and don't have access to a factroy torque spec I'll use a torque wrench to disassemble the part. I have SnapOn click type wrenches and just set whichever one I'm using to a low figure and click up half a turn until the bolt/nut breaks. Then it can usually be fine tuned a bit on a subsequent bolt/nut. Unless the fastener is rusted on this will get you close to what the factroy did.
Old Feb 27, 2009 | 12:37 PM
jmat1980's Avatar
Ok, those charts were somewhat confusing, plus I dont know what the thread per inch or grade of the bolt is...
Anyone have the torque specs for the 4 bolts that hold up the sway bar in the front...thanks..
Old Feb 27, 2009 | 12:47 PM
paramaniac's Avatar
X2 on this... Prob the best idea if you can't get a bettr answer. Its what I usually do
Old Feb 27, 2009 | 01:27 PM
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
per the service manual 45 ft lbs
Old Feb 27, 2009 | 02:08 PM
jmat1980's Avatar
Thanx
