Modifying Rubicon Rear
Old Aug 17, 2012 | 04:06 PM
Matches's Avatar
Default Modifying Rubicon Rear
Has anyone come up with a way to modify the rear locker on a 12 or 13 Rubicon to run it in 4high, 2high, and still use it in 4low ? I would like to be able to lock it up on occasion in high, especially in deep snow on the road.
I've got a lot of experience with lockers in trucks so I know the downsides but the upsides definitely outweigh them. I would like to use the standard rear w/o changing it out.
TIA
Old Aug 17, 2012 | 05:28 PM
JacksonH's Avatar
I've seen it done by either tapping into the locker relay and using a toggle switch or it can be done with some programmers such as the superchips.
Heres a write up for the switches: https://www.jk-forum.com/forums/jk-w...ication-88085/
Old Aug 17, 2012 | 05:31 PM
aldaman's Avatar
Here's a thread/write-up that BIGNICK recently did on his '12 that allows you to use the locker in both 4wd and 2wd...
https://www.jk-forum.com/forums/jk-w...cation-228408/
Old Aug 17, 2012 | 08:04 PM
Matches's Avatar
Thanks. Exactly what I was looking for. Much appreciated.
