mopar bumper winch
Old Aug 20, 2007 | 09:23 AM
SLICKWILL's Avatar
Default mopar bumper winch
hey guys,
i need to buy a winch and im not sure which kind to go with.. i wheel as much as i can and when i get stuck.. well lets just say it took a duce and a half to pull me out. lol
so with that said what winch do you think i should get and will it bolt right onto my mopar bumper.. if not what will i need
thanks
will
Old Aug 20, 2007 | 09:30 AM
BLKRUBI's Avatar
Will, I'm going to use a Tabor 9K. It's out out by Warn. If I didn't already have it, I'd probably try that Smitty built winch for $300.
Old Aug 20, 2007 | 09:44 AM
SLICKWILL's Avatar
any idea if it will bolt right in or will i need a winch plate..
or for that matter will any winch i use need a winch plate
Old Aug 20, 2007 | 10:13 AM
BLKRUBI's Avatar
The plate is built into the bumper, you don't need anything else but the winch. Warn's will work better on the Mopar bumper because that's what it is set up for, not that you can make something else work, but the fairlead mount is offset on the Mopar bumper to match up with Warn winches.
Old Aug 20, 2007 | 05:32 PM
retep's Avatar
I dropped a T-Max 10,000lb in my Mopar bumper.The holes in the bumper
didn't line up exactly, some filing was needed. Peter
