Mopar bumper and winch problem...
Old Apr 18, 2008 | 03:04 PM
brando13's Avatar
Default Mopar bumper and winch problem...
So I just picked up all my stuff, and started to install, and I ran into a clearance issue between the winch and the fairlead bolts on the bumper. For anyone who has installed a bumper on the Mopar winch, what kind of bolts did you use to attach the fairlead?
Old Apr 18, 2008 | 03:09 PM
FunN4Lo's Avatar
Not sure as I don't have the bumper, but what kind of fairlead is it? Hawse or roller. May make a difference.
Old Apr 18, 2008 | 03:11 PM
brando13's Avatar
Not sure why it would make a difference, but it's hawse.
Old Apr 18, 2008 | 03:14 PM
FunN4Lo's Avatar
I don't know, different leads maybe longer bolts or something. Just a quick guess. I know if you have pictures it would probably help. I'm sure someone that has that setup would anwser yr question pretty eaisly though.
Old Apr 18, 2008 | 03:15 PM
mgaspard's Avatar
I installed mine with the bolts on the back side of bumper with no washers. Installed nuts and lockwashers from outside. It was still tight but worked. It is a pain to tightedn.
Old Apr 19, 2008 | 09:58 AM
brando13's Avatar
Well, took the fairlead off, and tried to mount the winch without it even there, and it's still about 1/8" off just to mount the winch. Guess I have to go buy a new one!
Old Apr 19, 2008 | 10:38 AM
csorensen's Avatar
Which winch are you trying to put in? I had to buy a different fairlead for my Ramsey. I picked up the cheap Warn hawse that they sell if you buy from the stealers. I also had to put the nut/washer on the outside of the fairlead. It definitely was tight on the backside, but it worked out fine. I noticed when I did the install that the bumpers are definitely set up for the Warn winches.
Old Apr 19, 2008 | 10:41 AM
hurstrescue's Avatar
X2....I had the same issue with my Ramsey and Mopar bumper. Ended up using the warn fairlead also.
Old Apr 19, 2008 | 12:25 PM
brando13's Avatar
I can't even mount the winch to the bumper... the winch's body hits the plate where the fairlead bolts onto... I just confirmed, and my winch is exactly the same as an M8000 body wise... so it won't work either. Does anyone have a Warn M8000 on this bumper?
