Mopar or daynatrck?
Old May 21, 2010 | 04:38 AM
pini123's Avatar
Default Mopar or daynatrck?
Wonna change my jks dana 30 front axle to high pinion dana 44
which axle will suit me best ( for agrresive rock-crawling)
mopars rubicon or daynatracks pro rock ?
Old May 21, 2010 | 04:45 AM
subdude732's Avatar
im not a pro but I have always heard good things about dayatrck
Old May 21, 2010 | 05:38 AM
rmdchewie's Avatar
Dynatrac..
Old May 21, 2010 | 06:03 AM
opdsgt's Avatar
If you have the money to invest, it's really not a valid comparison. Dynatrac is without question the stronger, better engineered axle. A trail mate recently pulled his stock Dana from his 2-door JK and installed a ProRock 44. It's quite a thing to behold.
Old May 21, 2010 | 06:16 AM
Dynatrac's Avatar
Sponsoring Manufacturer
Pini-
With the exception of the locker, a larger u-joint and the 30 spline inner axle shafts, your Dana 30 is exactly the same as the MOPAR Rubicon axle. Check here to see some visual differences. https://www.jk-forum.com/forums/show...C-)-vs-ProRock
Scott
Old May 21, 2010 | 11:20 AM
pini123's Avatar
Originally Posted by dynatrac
pini-
with the exception of the locker, a larger u-joint and the 30 spline inner axle shafts, your dana 30 is exactly the same as the mopar rubicon axle. Check here to see some visual differences. https://www.jk-forum.com/forums/show...c-)-vs-prorock
scott
thank you all.daynatrac it will be,
Old May 21, 2010 | 11:21 AM
Lo2aY's Avatar
Dynatrac all the way
Old May 21, 2010 | 02:37 PM
popo343's Avatar
Go with the dynatrac Pro Rock 44. By the time you spend time and money beefing up the stock Mopar unit that you spent 3000.00 brand new just to change gears and axle shafts. The Dynatrac Pro Rock 44 is like 3600.00. All you will have to do is add your spindles and brakes from your D30 and you are ready to rock.
Old May 21, 2010 | 02:52 PM
Northridge4x4's Avatar
Sponsoring Vendor
I agree the Dynatrac housing is the way to go .
David
Old May 21, 2010 | 02:53 PM
Alaska-HWY JK's Avatar
Add Reid high steer knuckles instead of stock then you've got a tough 44.
