Mounting Air compressor
Old Jan 21, 2010 | 06:51 AM
Socal Tom's Avatar
Default Mounting Air compressor
I've got an MV-50 compressor left over from my Early Bronco days. I've looked under the hood and didn't see anywhere to mount it. What are people doing for to mount a smalle electric compressor?
Tom
Old Jan 21, 2010 | 07:39 AM
capt scotty's Avatar
My ARB compressor is mounted under the drivers seat. It is a little noisy when it runs but is out of the weather. I have seen others that have mounted thier compressor inside the rear fender behind the pass. tail light.
Old Jan 21, 2010 | 07:55 AM
horwitzs's Avatar
There is also a bracket available for under the hood mounting--> http://www.northridge4x4.com/proddet...ARB-JK-BRACKET
You might just have to drill a couple holes to match the bolt pattern on your compressor.
Old Jan 21, 2010 | 09:32 AM
jeepn7658's Avatar
I mounted one of mine behind the passenger tail light and then the other one inside the rear storage.
Old Jan 21, 2010 | 11:37 AM
KT'S-JK's Avatar
I have mine mounted in front of the battery. It is a small compresser but it will fill 150 psi in 4 min
This is where I have it stubbed out at one on each side
And this is the tank I built to fit between my slider and the frame.I hope it helps
