Mounting a high lift jack
Old Dec 28, 2012 | 10:14 PM
  #21
jorzac's Avatar
Dont need to buy a kit. A piece of angle iron, 2 4" pcs of 1/2" allthread, & 4 1/2 nuts are all you need to mount across the roll bar. Tap the 2 holes in the roll cage and mount it up high. The tension of the jack keeps it from moving. Its high enough to be out of the way, but you can reach easily. This is probably my cheapest & easiest mod.
ID:	403029   Click image for larger version
ID:	403030   Click image for larger version
Old Dec 28, 2012 | 10:40 PM
  #22
Maniacal's Avatar
I only see one piece of angle iron on the base. I'd like to try this one! At all possible I like to do things my own way. This is awesome!
Old Dec 29, 2012 | 08:07 AM
  #23
Whiskey Bravo's Avatar
Yeah a hi lift secured by velcro on top of everyone's heads does not sound very good.
Old Dec 29, 2012 | 08:10 AM
  #24
Also, i've got this same dilemma for my 2011 2door. It is currently on the hood but it blocks the sprayers and is in the way of fog-lights. Rear bumper not an option with my Smittybilt setup. Can you mount it atop the rear roll bar in a 2 door like a 4 door? I know the rear is shaped differently...
Old Dec 29, 2012 | 09:41 AM
  #25
MPSantiago's Avatar
Originally Posted by Maniacal
I actually thought about somehow mounting my jack under the rear seat of my JKU. I know I have a support brace under there. I hate the mounting points available. I don't want my jack available to be stolen and I'd like it out of the way for my gear and passengers. Has anyone thought up a well hidden spot to mount their high lift? Any input would be awesome! If you have pics that would help too.
Thank you in advance.
Is theft really a major concern? I put mine on the back hinges with a Rugged Ridge mount, secured with a small bike cable and lock. Not 100% theft-proof but it'll deter the opportunists. The biggest selling point for me was that it was out of the way, didn't interfere with switching between soft and hard top, and was easy to access.
Old Dec 29, 2012 | 10:01 AM
  #26
jk4thedirt's Avatar
Hold you jack up there and see if it fits. The jack setup from jeep swag is the same height as the roll bar. Maybe a little lower.
Old Dec 30, 2012 | 11:40 AM
  #27
KG6SLC's Avatar
Default Hi-Lift Mount
Here is my Hi-Lift installation, out of the way, readily available, and lockable! (and easy to make)
KG6SLC aka Eugene
Old Dec 30, 2012 | 06:53 PM
  #28
Ruubdood's Avatar
Originally Posted by NCRUBI2012
Attachment 402951
My install idea. Might move inside later. Add a lock and good to go.
I'm buying what your sellin'
Old Apr 13, 2013 | 06:29 PM
  #29
Maniacal's Avatar
I ended up putting it under my back seat and using Velcro to secure it to the vertical seat supports. Works great and people can't steal it and it cost me about 5 bucks of Velcro.
