Movin' on up!!!
Old Feb 25, 2011 | 09:17 AM
Vincent's Avatar
Default Movin' on up!!!
Well, headin' towards the 35's so i need some lift...right now i have the teraflex leveling kit...should i just add a body lift or go the TF2.5" coils or OME??? I'm in between the TF 2.5" & OME but don't really plan on getting huge heavy bumpers...next thing i plan to get is the OR-FAB tire carrier w/ Jerry cans mount and Superwinch mounted on the factory bumper. I don't want all the weight really. 2nd question i guess is, do i need FR adj. trackbar & adj. control arms for the ride or is that overkill? And i guess the 3rd question is..if OME do i go HD since i don't plan on adding too much additional weight??? Why can't i be satisfied with what i have???
Old Feb 25, 2011 | 09:34 AM
HG07JKRubi's Avatar
Sounds like you plan on adding a winch...they are heavy too so I would do a coil lift instead of the spacers.
Because you own a Jeep... and it probably won't stop with the lift
Old Feb 25, 2011 | 09:37 AM
BKGM Jeepers's Avatar
If you plan on subsequent mods, go with a coil lift. Also, as stated above, you'll eventually go with subsequent mods. Personally, I've seen great support from TF on their products.
Good luck!
Old Feb 25, 2011 | 10:31 AM
xxlrg's Avatar
Man I just put a TF 4dr 2.5 coil lift with adapters on my 2dr Sahara and love it! Drive way better than stock. No ill effects at all! Would highly recommend. Looks great with 35's
Oops sorry could have swore you had a 2dr. But still very impressed with the kit!
Old Feb 25, 2011 | 10:35 AM
Olean NY Jeeper's Avatar
I believe a 2.5 coil lift for 4 door is actually the same springs as 3 ich coil lift for 2 door, right?
