Mud tire choice
Just installed Bushwacker Flat Fender on my JK
now with stock suspension, my JK is good to clear 33 inch tire.
Now I am facing a wide range of Mud tire choices.
So far I narrowed down to the following tires
Good Year MT/R with Kevlar 305 70R16
BFGoodrich KM2 305 70R16
I am planning to use 16x9 steel wheel with 5 inch backspacing.
How do you think about the tire, also, is my wheel choice good or bad.
By the way,Did anyone tried 34 inch tire for the same situation as mine?
As for the wheel, I prefer to have it 9 inch wide. but it seems no 16 inch wheel
has 9 inch width. SO I guess I have to use 8 inch width.
I am not sure if this will cause problem because the tire is 12 inch wide
x3 on the BS. And I like my KM2's I'm not sure that MTR's are quiter but I would agree they have a stronger sidewall. The Side wall can be a benifit or a problem. My KM2's aired down have a great pattern at 12psi and are crazy at 7-8psi.
Also I'm running 35x12.5 on 8 inch rims and think its perfect. I was with a guy running 12.50 on 10" rim and rolled his tire off the rim on something I walked through with no problem. So if I were you I'd go 8 over 9, Although this advice all centers around trail riding.
