Muffler Location Question
Old Oct 24, 2008 | 04:22 PM
officer_vince's Avatar
Default Muffler Location Question
Two questions:
1) Can I mount a Flowmaster Super 44 close to the evap canister on a 2DR safely? Looks like it would be cutting it close....
If not then:
2)Anyone mounted a flowmaster (or similar) muffler in the stock location, but higher up and more out of the way?
I'd like some pics and may a bit of a write-up.
I'd want to show the exhaust shop how to do it...so it is at least better than the factory's enormous rock magnet.
Thanks!!!
Old Oct 24, 2008 | 04:53 PM
LemonTwist's Avatar
I'll say it first. Relocate the evap canister, then there is plenty of room, and THAT plastic rock magnet will no longer be a problem waiting to happen.
Old Oct 24, 2008 | 09:21 PM
aldaman's Avatar
Not a flow master, but gives you an idea of the clearance between the muffler and the Evap canister if you choose not to relocate the evap at this time...Been running this set up for a while with no issues on the canister & the muffler being that close to each other....
Old Oct 25, 2008 | 03:31 AM
Choppus's Avatar
I feel like an idiot, but I have to ask. What is the Evap canister? I have seen the Evap canister relocation brackets and lots of people talking about doing the mod. I can see it's prone to breakage in it's current location.
Old Oct 25, 2008 | 05:07 AM
aldaman's Avatar
Below is the general information of that part:
Originally Posted by WikiAnswers(tm)
An evaporative canister is part of the evaporative system that is within the emission system. Hydrocarbons are a form of pollution that gasoline releases as it evaporates or after is is burned. While fuel is stored inside the tank, fumes build up and are retained inside this canister. The canister contains charcoal that absorbs the hydrocarbons. When the engine is started, a valve opens that allows fresh air to come in and purge the fumes (hydrocarbons) into the air intake and then into the combustion chamber for burning. I understand that more hydrocarbons are released into the atmosphere by leaving your fuel cap off, than what comes out of your tailpipe while the engine runs. If there is a leak anywhere in the evaporative system, such as a bad hose, canister leak or leaving the fuel cap loose, the check engine light will set.
Old Oct 25, 2008 | 12:33 PM
In other words
Evap Canister - "Invented by hippies".
Old Oct 25, 2008 | 01:35 PM
JKAdam's Avatar
Originally Posted by 4LO
I really like that setup. Did you buy that as a bolt on kit, or was that fabbed up?
Old Oct 25, 2008 | 04:47 PM
RedneckJeep's Avatar
Doesn't hang too low. But I am going to move it up a little for more track bar clearance, since my axle is stretched back 1.25". All I gotta do is rework the hangers a little. Piece of cake. I'm building a 3-link rear and ditching the rear track bar, so I'll probably re-locate the muffler somewhere else later.
It's a bolt-on kit from Rusty's Offroad. It's sold as a Cherrybomb muffler, but is actually a Flowmaster 50. Pretty good deal.
Interesting lookin little muffler. Do you have any sound clips?
Old Oct 25, 2008 | 06:28 PM
mikeyfl's Avatar
Vroom Vroom...
that does sound nice. kinda throaty, but not ricey at all!
Old Oct 26, 2008 | 06:16 AM
micja's Avatar
I did exactly the same thing but i did a side exit on the passenger side. i did it so i would be less likely to hit it on stuff. It has worked so far. Plan to relocate down the road but it works for now.
