My new setup advice
My new setup advice
Finally got around to taking the next step, moderate wheeling planned. I've done a ton of reading and I know thishas been beaten to death but I'm still confused About a few things.
08 JK unlimited rubicon
My plans
315/75/16 Duratrac on procomp 7005 wheels
Mbrp exhaust
1" body lift. Undecided on brand
2.5" teraflex BB with adapters or 2.5" coil lift with adapters
From what I've read the bb is complete and the rubicon shocks are good, but the coil lift will give me more height and more articulation. Am I going to need adjustable track bars wih the coil lift thou?
The bb is 364
The coil lift is 522 wich is OK but add trackbars if they are needed and is now getting fairly pricey.
My plans
Mbrp exhaust
The bb is 364
I personally would go coils. As far as track bars you will get relocation bracket for rear and the front is not required so go ahead and go without and drive it for a while see what you think and add it later if you want. I pretty much run exactly what you are thinking of doing so feel free to hot me up with any questions.
As bobby stated, Front Trackbar isn't necessary on 2.5" lift. If you find one for cheap used, it's good insurance, just like sleeve and gusseting. I run a 2.5" BB and don't have either track bar or brackets... Been looking for a rear bracket for cheap.
If you are set between the 2, I would suggest the Coil lift. It is more expensive, but it will make your ride quite a bit smoother.
You can always buy the Coils used and it would be a bit cheaper, then piece together the lift. That's what I'm doing, slowing buying my lift used.
2.5" bb = no trackbars needed just the brackets
2.5" coil but actually gives over 3" especially with stock bumpers and no winch. Will I need it?
What do you think will happen? I am unsure as to what you are worried about. The more you lift up the more your front axle wants to uncenter. In our case the track bar axle mount is on passenger side so you will move your axle a fraction of an inch to the drivers side. When I did my lift I had an ESP light come on around corners with speed. Turned out this went away completely when I get my steering wheel perfectly centered. So as far as I can tell my adjustable front track bar has done nothing as far as driveability or at the most it has not done enough to improve it for me to deem it necessary. However it seems as though you want to buy one. So if you want to buy one then buy one. But I would bet a small fortune that there is more people out there running a 2.5" coil lift without a front adjustable track bar then there is with. Hope this doesn't seem like a rude reply just want to make it clear.
Wheels and tires sound fine. I'd personally skip the body lift. It's not needed and I don't like the look or the trouble it takes to get an inch of non-frame lift. The coil lift is a better option than a BB, and you don't have to do trackbars right away. You can always add them later. You axles will be a little off center, but it's really no big deal. I'm not a big fan of trackbar brackets when you can just buy an JKS adj. trackbar for $200 and not risk have a weak point in your suspension setup.
