My thoughts on lifts
Old Oct 15, 2013 | 04:24 PM
  #21
WranglerJA's Avatar
Default Being thrifty doesnt pay off long term
Very thorough. I bought mine with 3.5" thrifty lift (acutally height is 4") w 35's. The selling point to the bride was "it's all done....just a few mods here and there". In the first month I've replaced most parts, added more and more to do to get it right. Although I like the look of a taller lift and bigger tires, if i were to do it all over agian I'd prob opt for a smaller lift/tire combo.
Old Oct 15, 2013 | 04:31 PM
  #22
Offroad's Avatar
Originally Posted by TheDirtman
If you were to compare two Jeeps, one set up with a 4" short arm kit on 33" tires and one with a 2" lift and 37" tires with trimmed fenders the one on 37's, if properly geared, would run circles around the higher lifted Jeep. It would climb better, clear bigger rocks, be more stable in off camber situations, and would handle better on road due to the lower center of gravity. Both Jeeps would be the same height overall.
Great info. I totally agree that a Jeep with 37s and a 2" lift would outperform off-road one with 33s and a 4" lift. But why would it have a lower center of gravity?
Old Oct 15, 2013 | 04:36 PM
  #23
TheDirtman's Avatar
bigger rubber closer to the ground
Old Oct 15, 2013 | 05:25 PM
  #24
Offroad's Avatar
But aren't the axles closer to the ground with 33s?
Old Oct 15, 2013 | 06:25 PM
  #25
deagonkennels's Avatar
Thanks Dirtman. I learned something new today.
Old Oct 15, 2013 | 06:36 PM
  #26
Maertz's Avatar
damn good write up....if i had to get an actual kit i would install everything then measure the shock lengths i needed for my tire size and set up.
Old Oct 15, 2013 | 06:38 PM
  #27
Maertz's Avatar
yes but you are changing way more suspension geometry pushing the axles down more than just raising it all via tires.. Also you axle will be higher off the ground for clearance.
Old Oct 15, 2013 | 07:06 PM
  #28
Offroad's Avatar
Totally agree with that, but I'm only talking about which one has the lower center of gravity, not which one is or rides better.
Old Oct 15, 2013 | 07:36 PM
  #29
Bushmaster's Avatar
What about a body lift to raise the fender flares to fit the larger tyres and allow for stock flex?
Old Oct 15, 2013 | 07:37 PM
  #30
jk_sea's Avatar
Good writeup. Thanks for posting!
