Is it necessary to remove front grill to replace stock bumper?
Old Sep 3, 2009 | 05:53 PM
saharaJK231's Avatar
Default Is it necessary to remove front grill to replace stock bumper?
Thinking of possibly replacing my stock bumper with the Mopar off-road bumper w/ NO winch (just like the look of it and don't need a winch)- I notice the instructions say that you need to 1st remove the grill (and plastic part where a winch would go) but I don't see the reason if you can get to the bumper bolts from under (after removing the air dam, of course)- any thoughts/advice?
Old Sep 3, 2009 | 05:56 PM
lv jk's Avatar
***erator
Took mine off with out removing the grill.
Old Sep 3, 2009 | 06:05 PM
mkjeep's Avatar
When I took mine off, I didn't even take that plastic cover thingy off, till later.
Old Sep 3, 2009 | 07:21 PM
i have a rugged ridge and no i never had to remove the grill
Old Sep 3, 2009 | 07:57 PM
Originally Posted by MarcusRTJ
Just FYI the front grill comes off VERY easily. I don't even think tools are required if I remember correctly.
all you need is a phillips head screwdriver and it takes about 5 minutes
Old Sep 3, 2009 | 08:01 PM
AlmightyCrash's Avatar
Grill stays.
Old Sep 4, 2009 | 05:25 AM
Thanks! Appreciate the input- I thought it wasn't but just making sure...
Old Sep 4, 2009 | 12:44 PM
Originally Posted by saharajk231
thinking of possibly replacing my stock bumper with the mopar off-road bumper w/ no winch (just like the look of it and don't need a winch)- i notice the instructions say that you need to 1st remove the grill (and plastic part where a winch would go) but i don't see the reason if you can get to the bumper bolts from under (after removing the air dam, of course)- any thoughts/advice?
took mine off with out removing the grille. Maybe they say this to protect it from damage while installing the bumper
Old Sep 4, 2009 | 09:42 PM
nangulator's Avatar
Originally Posted by Denny2565
Required - no
makes it easier if you're installing by yourself - yes
X2, It only takes about a minute to take off and makes a bumper/winch install much easier
Old Sep 4, 2009 | 10:30 PM
Foo's Avatar
Foo
I just put on Rugged Ridge stubby on and no need at all to pull the grill.
The hardest part is getting those plastic screws out.
Someone said to have a drill to drill out the plastic screws (that don't unscrew), I gave up in frustration and used a crow bar, pooped them right off or though!
