When adding a Lift
So i plan on putting in a 2" Tera Flex lift and a 2" skyjacker coil spring spacers
kit what will i have to do in order for this set up to run smoothly. like will
i have to add longer tubes or anything? this is my first time lifting my JK
so i just want to fully understand what i have to do some everything works
the way it is suppost to and that i don't have any issues down there road.
Also will i have to run long arms with this set up?
thanks
thanks
i did a skyjacker 3.5" basic coil lift and i didn't have to change anything aside from what the lift kit had in it. i don't know if the same will be true for the teraflex since actual lift varies per manufacturer, but if it really is 2" you don't have to do a whole lot to the jeep
ya even tho he is soooo against wheeling lol
really the last shop i went to said that if u don't have the rubi then
you would have to move your T-case?
