Need Ball Joints Replaced
Old Dec 19, 2012 | 03:47 PM
  #21
yo_marc's Avatar
Originally Posted by JKingAround
Put a 90* zerc fitting on the ball joint
They actually do come with 90's, but they are too tall.
They also come with a brass plug for that one grease point, as if they are aware the included hardware wont clear the shaft.
Old Dec 20, 2012 | 09:14 AM
  #22
robinson86's Avatar
You must not have Moogs then...I already tried it. The u joint is closer to the top of the lower ball joint than you might think (actually about 0.375" gap) and would still knock the 90* zerc (0.569" tall) off the perch. Actually a 90* zerc sticks up higher than a straight zerc. The only option is a flush mount grease fitting that requires a needle tip on the grease hose, only they don't make them in a 1/4 28 SAE-LT tapered thread in that size.
Old Dec 20, 2012 | 09:48 AM
  #23
OVRNUNDR's Avatar
Flat needle fittings will work, 6 bucks for a small package of them.
Old Dec 20, 2012 | 09:53 AM
  #24
robinson86's Avatar
Where can you get them in a 1/4 28 tapered thread? I already ordered 1/4 28 straight thread from Grainger and they wont fit.
Old Dec 20, 2012 | 12:57 PM
  #25
yo_marc's Avatar
The 90* zerk fittings I have on my Moogs clear the u-joint by about .050. It's really close. But there are no issues...
I'll grab the name off the package. I bought them ages ago so I'm not sure they're still around.
(are there differences in u-joint diameter between the Dana30 and Dana44? Note that I have a Sahara.)
