Need comments about loctite
Old Oct 30, 2009 | 05:00 PM
Yoda's Avatar
Default Need comments about loctite
I received the Performance Accessories 1" body lift today (thanks Stan ) , and it includes a Loctite tube. The other body lift manufacturers don't include this product.
What do you think of Loctite? I heard that you have to heat the bolts (with Loctite) if you want to remove the body lift.
Comments please
Old Oct 30, 2009 | 05:11 PM
robin's Avatar
in my experience loctite works really good I've used it in my wheels, and I don't think you have to heat it up to take them off however it does become a lot harder to undo a screw, but to me that's why is there for
Old Oct 30, 2009 | 05:13 PM
codysanders's Avatar
it is a great product and i would recomend using it. you can get the bolts out if need be. just remember to tork to proper specs. i would use the blue (md strength) if you have a choice. good luck and post up some pictures when your done.
Old Oct 30, 2009 | 05:16 PM
w squared's Avatar
What colour of loctite did they send you?
Blue = a little extra work to remove the bolt/nut/screw, but no biggie.
Red = a lot of extra work
Other colours = get out your torch.
Old Oct 30, 2009 | 06:14 PM
seer1's Avatar
Red. If you're gonna go, go large. It doesn't need heat and holds stuff quite securely. If it's a little tough, use a longer wrench.
Old Oct 30, 2009 | 06:17 PM
mkjeep's Avatar
No locktite on my bl mount bolts and they're fine after a year and a half.
In fact, I plan on putting neverseize on mine before long. Ever taken out body mount bolts that were on for several years of off-roading. Get out the drill and torch.
Old Oct 30, 2009 | 06:23 PM
Yoda's Avatar
RED
In the instructions, i read that you have to heat the bolts at 450 degree if you want to remove the BL
Old Oct 30, 2009 | 06:25 PM
JayhawkJeep's Avatar
Veteran: Navy
How long do you plan on using this for?
Old Oct 30, 2009 | 06:32 PM
Nozz's Avatar
Are you planning on taking it off You dont need it but you might want to check the torque on the bolts every once in a while. You'll know if they get loose. My buddy had some rusted out mounts and when you turned a certain way the whole cab tipped
Old Oct 31, 2009 | 03:55 AM
Yoda's Avatar
Well, no more comments?
