need help, can i run 2"-4" shocks with leveling kit
Old Jun 13, 2014 | 01:49 PM
forestJK's Avatar
Default need help, can i run 2"-4" shocks with leveling kit
I have shocks thats for 2" to 4" lift. Can the teraflex leveling kit 1.5 work with those size shocks i already have. Would daily driving and trail rides be ok?
Old Jun 13, 2014 | 02:07 PM
aaronstephen's Avatar
What are the compressed/extended lengths of the shocks?
Old Jun 13, 2014 | 02:18 PM
forestJK's Avatar
well i called the guy who sold them to me awhile back and he said he can't tell my the extended length, they just make them for 2-4"
Old Jun 13, 2014 | 02:30 PM
Rob 12B1P's Avatar
You might need to bumpstop to keep the shocks from bottoming out. That and you might need spring retainers in the rear to keep them from popping out.
Old Jun 13, 2014 | 02:39 PM
nthinuf's Avatar
In addition, you could also look in to a synergy relo kit for chopping off and relocating the shock mounts. They make both upper and lower, but you could use just the upper one to give more extension.
Old Jun 13, 2014 | 02:41 PM
TeraFlex's Avatar
Sponsoring Manufacturer
I would look up the part # on the shock and find the specs. I would only suggest running 2.5" shocks with bumpstops on a leveling kit.
Old Jun 13, 2014 | 04:35 PM
Jeepnut67's Avatar
Question Hey Teraflex,
I'm in a similar situation with your spacer leveling kit. I'm looking at getting new shocks that I can later use on a 2.5" coil kit. I'd rather not have to buy shocks twice. Can I safely use shocks for a 2.5"?
Old Jun 13, 2014 | 10:06 PM
davison0976's Avatar
For the front shocks, measure the extended length (middle of the eye to middle of the eye). For a 2 Dr it should not be over 24.5", otherwise your front drive shaft will rub against exhaust pipe that crosses over. I went with 1.5"-3.0" fox shocks instead of the longer ones for that very reason.
Old Jun 14, 2014 | 03:34 AM
forestJK's Avatar
pm sent.
