Need help with Electronic Disconnect install
Old Jun 23, 2008 | 10:30 AM
BYU JK's Avatar
Default Need help with Electronic Disconnect install
I looked through the write-up section and didn't find anything for installing the rubicon electronic disconnect. I purchased one for my saharra with all the switches and wiring harness and will be installing it shortly but wanted a game plan before I start. Let me know if you have any information on this. Unlike Clackey, I don't like to just "crawl under the jeep and figure it out as we go along." But that might be what we have to do.
Old Jun 24, 2008 | 09:26 AM
BYU JK's Avatar
Come on, with all these jeepers someone has to have done this before.
Old Jun 24, 2008 | 10:00 AM
Piginajeep's Avatar
I installed this on my X, its a straight up, unbolt, rebolt your new disco. 4 bolts for the sway bar, and two bolts on the links.
Did you get instructions with the harness? I took pictures for a write up, but have yet to do one yet. If you need them. I'll get the online tonight.
The wiring is simple, but the mopar directions, make it confusing...when its really not.,
Old Jun 24, 2008 | 10:46 AM
BaltChief's Avatar
Wow, your Jeep is different than mine. I only have 2 bolts on the sway bars and 4 on the links..........someone was gonna do it, just as well be me.
Old Jun 24, 2008 | 10:55 AM
Piginajeep's Avatar
two on the clamp, each side. One on the sway bar link,. No need to disconnect it from axle.
Old Jun 24, 2008 | 01:29 PM
BYU JK's Avatar
I figured the the install of the actual sway bar wouldn't be to difficult. I would love to see the wiring and switch install write up because it came with nothing. Thanks for the help with this. I'm excited to not have to crawl under the jeep anymore and take off my "quick" disconnect with a crow bar. It's going to be great just to push a button.
Old Jun 24, 2008 | 05:15 PM
Piginajeep's Avatar
let me doing some digging, It seems I miss placed the pictures..
Old Jun 24, 2008 | 07:42 PM
BYU JK's Avatar
Thanks, I look forward to seeing it.
Old Jun 24, 2008 | 08:13 PM
CLACKEY(_!_)'s Avatar
Huh. I guess you're doing this one by yourself?
Old Jun 24, 2008 | 08:28 PM
BYU JK's Avatar
What I meant to say was "I'm just not as skilled as Clackey so I need instructions." Ya, that's what I meant to say. Hey, aren't you suppose to be coming over?
