Need help Fast! PR44 + Evo Coilover Install
Old Aug 23, 2015 | 12:03 PM
devwil68's Avatar
I am in the process of installing my bolt in evo front coilovers and have run into a challenge: I have a PR44u and the lower spring brackets are a little off I think....has anybody installed this kit with a a Dynatrac PR44? How do the lower brackets go in correctly or do I even need them?
Old Aug 23, 2015 | 12:05 PM
951Rubi's Avatar
Gonna need more info to help you out. Do you have any pictures?
Old Aug 23, 2015 | 12:07 PM
devwil68's Avatar
Attached
Old Aug 23, 2015 | 01:26 PM
ronin2120's Avatar
Vet Army
I cut the stock ones off and welded the new brackets onto my axle, but that's on my stock axle with rock krawler coilovers.
Old Aug 23, 2015 | 01:42 PM
Albino Lizard's Avatar
Originally Posted by devwil68
I am in the process of installing my bolt in evo front coilovers and have run into a challenge: I have a PR44u and the lower spring brackets are a little off I think....has anybody installed this kit with a a Dynatrac PR44? How do the lower brackets go in correctly or do I even need them? <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=622391"/>
You have that bracket on the wrong side.
Old Aug 23, 2015 | 03:25 PM
JE8154's Avatar
Attachment 622401
was going to say this prior to reading down.
Old Aug 23, 2015 | 03:27 PM
TURTLECON's Avatar
You have that bracket on the wrong side. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=622401"/>
^^^^Yep. Attention to detail is important.
Old Nov 14, 2015 | 05:58 AM
devwil68's Avatar
So, a follow up to this old thread. I did cal EVO that day and was informed that the PR44u axle does not require these brackets to be used with their coil over system. Just with the stock axle.
