Need help on TF 2.5
Old Jan 23, 2011 | 02:20 PM
snopro269's Avatar
Default Need help on TF 2.5
Installing this lift and not sure what the instructions are talking about installing rear coil spring guide and spacer. I see it on the install of 3 inch but not 2.5 kit. I'm not going to run the factory isolators yet and there is nothing else in my kit besides a pair of brackets flat washers and bolts. I installed the lower retainers but not sure what's with this other bracket. Or is it the brake line relocation bracket?!?
Old Jan 23, 2011 | 02:28 PM
mkjeep's Avatar
I know some kits come with a rear 1/2 coil spacer that has a long nipple on it( hence guide)
duci05's Avatar
They arnt included with the kit anymore, i just went through this too. Re use the factory rubber piece from top of the spring
I called terflex and this is what they told me.
Old Jan 23, 2011 | 02:29 PM
mkjeep's Avatar
pic of the bracket would be helpful too.
Old Jan 23, 2011 | 02:33 PM
duci05's Avatar
I forgot to add, its only kits with out shocks that no longer have the 1/2 spacer spring guide
Old Jan 23, 2011 | 02:34 PM
stlfan06's Avatar
If there's 2 identical thin aluminum brackets, those are the brake line extension brackets. If it's one thick black steel bracket, that's the rear trackbar relocation bracket.
Old Jan 23, 2011 | 02:35 PM
snopro269's Avatar
Ok so the bracket is the brake relocate I fig that out but I have like 4 washers that came in the kit. They are the same size as the washers to bolt on the trackbar. Pretty large in diameter.
Old Jan 23, 2011 | 02:36 PM
snopro269's Avatar
My stinking IPhone can't add with this app
snopro269's Avatar
I'm using my factory rubi shocks with extensions
Old Jan 23, 2011 | 02:37 PM
snopro269's Avatar
That track bar locate kit. Do I drill the frame for that one bolt then
