Need help on TF 2.5
Old Jan 23, 2011 | 02:38 PM
snopro269's Avatar
Originally Posted by stlfan06
If there's 2 identical thin aluminum brackets, those are the brake line extension brackets. If it's one thick black steel bracket, that's the rear trackbar relocation bracket.
There's four huge flat washers left. Plus two more for the trackbar kit
Old Jan 23, 2011 | 03:20 PM
Feasterdef's Avatar
Are they the washers for the rear coil springs? The bolt goes through the washer and mounts to the axle on the bottom of the rear coil.
Old Jan 23, 2011 | 03:38 PM
Biginboca's Avatar
Those aren't them. I know the washers he is talking about. I had them left over afterwards because they are not mentioned in the instructions. They are about the size of half dollars and there are 4 of them. I thought maybe they have something to do with the swaybar links... but I couldn't figure out where they would be needed and just threw them out after I was done...
I would love to know what they are for also. It's been bugging me for a while!
Old Jan 23, 2011 | 05:32 PM
snopro269's Avatar
Yeah I might call TF in the AM and see what they are for. I got the rear lifted so maybe tomorrow the front gets done as well!! Thanks everyone for help !!!
Old Feb 5, 2011 | 07:53 AM
Hawnted's Avatar
I have them left over as well. Did you ever figure out what the are for? They are the only parts not in a labeled bag and are not mentioned in the instructions, or on the parts list.
Old Feb 5, 2011 | 09:11 AM
joe a's Avatar
Same here, did my lift yesterday and have four washers left.
Old Feb 5, 2011 | 11:28 AM
Hawnted's Avatar
Originally Posted by Mark in Va
I used 3 of the 4 for the rear track bar relocation bracket and track bar installation. One on either side of the track bar bolt at the frame relocation bracket and one on the track bar bolt at the axle.
I had washers included for the trackbar bracket.. I guess they are just extra.
Old Feb 5, 2011 | 01:56 PM
snopro269's Avatar
I used two of them fir my front shocks underneath the stock rubber bushings. The stock ones were thinner so I put in the thicker ones instead. But still have two washers left !! Spares I guess!!
